Question about Toshiba SD-V394 DVD Player/VCR
Toshiba dvd Video player & vcr SD-V396SU2
This player is 2 yrs. old. a couple days ago, the VCR recorded tapes began "jumping", as in lack of vertical hold. I tried auto and manual tracking, bought a head cleaner tape, bought new VCR tapes, all to no avail. At times multiple images appear and the sound is muffled.
  • 1 more comment
  • Anoyed Dec 10, 2007
    Same problem exactly. The machine is 2 years old and 2 weeks ago I taped a program, sat down to watch it and no vertical hold. I tracked and auto tracked, threw out the tape bought a new tape, cleaned the heads taped again. Same problem. Played the tape in another vcr and it played fine. Put in a tape recorded on another machine, same problem, no veritcal. How do I repair or do I bother?
  • gone to pot Dec 13, 2007
    message for Anoyed - I took my Toshiba SD-V396SU2 to an electronics repair place who charged $20 for estimate. He told me the SLP head was worn out, but to try recording with the SP (standard play) head. IT WORKED! We have a Sony VCR that had the same problem (for which we bought the Toshiba to replace, but which I still kept). I set the Sony recording settings to Standard Play also, and it now works too.
    The other point of information from the electronic repairman was that we could connect a new HD DVD player VCR combo without a tuner, to the old analog set, and use the tuner until everything goes digital in Feb. 09.
    Hope this helps.
    gone to pot
    another comment for Anoyed...You said you replaced the unit with a JVC. Was that a dvd player, VCR Combo? Our search for a replacement was futile because we could not find any new sets with built in analog tuners. All required either a cable box or a tuner in the TV, neither of which we have. Hence, the visit to the repairman.
    What is the model of JVC you purchased? do you mind divulging the retailer and the cost?
    Thanks.
    Gone to Pot
Thanks. We have replaced the unit with a JVC but will give the SP/SLP a try just to see.
Anoyed
Posted on Dec 13, 2007
  • Anoyed Dec 14, 2007
    Message for gone to pot
    The unit we purchased was from Sears and is actually exactly like the Toshiba. It is a JVC DVD/VCR combo unit (model number is at not at hand but I can get it for you) and cost was $119.00 regular $129.00. I just looked for it on line but couldn't find it. I bought it at our Catalogue office. We did find that there may have been more wrong with the Toshiba than we knew. We are not big electronic wizards and when we bought the Toshiba it was our first DVD. We played a few rentals and then attempted to play one given to us after an athletic event. It didn't freeze entirely but the mouths never matched the words. It was not pleasant to watch. With the new JVC we put in the same DVD and it played perfectly. We do have an older tv but we do have it hooked up through our satelite so I am not sure if it would have what you need. I would be happy to look in the manual for you if you told me what to look for.
    Anoyed
SOURCE:
My Magnavox VCR/DVD combo groans when I set the timer recording. It doesn't make the noise when I turn it off.
I hate to sound elitist or negative, but VCR is over, much in the same way that cassette tapes are over. It is even getting hard to find DVD recorders which stand alone. Additionally, I would urge you to record all of your home movies and significant recordings to DVD while you can. VCR tapes degrade pretty rapidly compared to DVD. And now, even DVD is on the way out. Get up to speed. You'll be glad you did!
Jan 18, 2018 | Magnavox DV225MG9 DVD Player VCR
Since change over to digital dvd/vcr Toshiba SD-37VB does not record on Video tapes. What do I need to do to correct this or do I need to purchase some additional unit?
Subcribe to cable or satellite tv services.Ur dvd/vcr unit will able to be used to record on VHS tapes again.Because cable or satellite tv services the tv incomming broadcasting tv signal still do broadcasting comming in as analog tv signal for the analog devices as analog devices require as it needed.
Apr 27, 2011 | Toshiba SD37VB DVD Player / VCR Combo
I cannot get it to record a vhs tape to a dvd. The vcr will play tapes and the dvd player will play dvds. I need some one to walk me through what buttons to push to record.
You need a remote to setup the dvd record and vcr record. Then you have to do dvd initialization perhaps before you can dub from tape to dvd?
Dec 20, 2010 | Toshiba DVR610 DVD Recorder/VCR
When I record a movie on the vcr it plays back snowy.
Ur VCR signal recorded free air throught an DTV converter box?Yes,this cause is normal,because VCR player have no digital tuner on the VCR player by itself,on it circuitries design.If recorded throught pay cable signal.Yes,than ur VCR video head player is dirty needed to be clean.Tries websites like Amazon.com,Ebay.com to buy a VCR video head cleaner vdeo tape.Just play it as normal as a video tape,when the video head clean,VCR will display clean head eject tape now.
Aug 03, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
How do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
VCR Issue with Toshiba SD-V295KU
This may be a bit late but I just ran across these posts. All these problems can be caused by bad tapes. Commercially-made tapes will usually play properly. But home recorded tapes, or very worn tapes, may not play back properly in every VCR. If the VCR isn't getting the right information off the tape for proper playback, it's muting the sound and the screen so you don't see any snow. It's also possible that the VCR heads already need a cleaning. It takes just one worn-out or defective tape to clog up the heads and cause the "no picture" problem, although in this case sound isn't usually affected.
Dec 21, 2008 | Toshiba SD-V295
CAN NOT RECORD
Returned it to store,got adifferent brand name
Aug 19, 2008 | Philips Magnavox DVD/VCR Dual Player
Toshiba model sd-v383sc
Atrk means that the unit is in auto-tracking mode and trying to lock in to the tape's recorded speed. This should go away after a short period of time once the tape has started.
Dan
Jun 19, 2008 | Toshiba D-VR4 DVD Recorder/VCR
VCR thinks ALL tapes are write protected.
the record tab detection switch inside the machine is broken
Dec 12, 2007 | Toshiba SD-V392 DVD Player/VCR
Toshiba SD-V394 DVD Player/VCR Logo
234 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
