Question about Bose 3 2 1 GSX System
DVD WITH THE BOSE 321 SYSTEM
THE DVD IS STATING OPENING BUT IT WILL NOT OPEN UP SO THAT I CAN REMOVE THE DVD. IT STATED DISC ERROR PRIOR TO NOT OPENING. I HAVE TRIED TURNING IT ON AND OFF TO NO AVAIL.
  • tpr0729 Dec 13, 2007
    This was great advice!!! It worked and the DVD has been removed!!!
  • Anonymous Dec 20, 2007
    I have the BOSE 321 system and the dvd is stuck in the closed position, meaning I cannot open it to retrieve the dvd.....VERY annoying......
I unplugged the unit then plugged it back in. The DVD ejected.
Posted on Dec 07, 2007
Bose 321 tray will not open
If it's flashing on and off, then the DVD drive is the least of your problems. Check to see if there is a dual-voltage switch on the bass module. (if so, set it to 120v if you're in the US) As for the DVD drive--> Try another reset by unplugging the power for at least 30 seconds. Plug it back in, "Bose 321" will appear and disappear from the display, and then press the eject button before you power it back on. Wait about 3-8 seconds. If the drive won't open, it will probably need a repair. $150 for repair w/ new warranty through Bose- 800-367-4998.
Jun 21, 2009 | Bose (321GS) System
When I press the Eject Button on the Bose 321 DVD Player the tray does not open up. I can hear the sound as if trying to open
normal issues with cd/dvd trays - gear/rubber of the tray transport worn out.
manytimes it helps if you always keep a cd/dvd in the tray (don't keep the tray empty)
it may also help if you can keep the bose 321 vertical.
May 30, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Unlock code bose 321 GS III series
1. Insert a DVD which does not work due to region code error, then
2,.- Press right arrow
3.- Press up arrow
4.- Press Shuffle Button
5.- Press Stop Button
6.- Press and HOLD Mute Button
The tray disc will open and the will close.
Thats all....the Bose DVD media will be Multiregion....
May 30, 2009 | Televison & Video
My bose 321 won't play DVD only CD
your problem is very easy just open the unit and replace a new one lens or maybe if you dont understand just text me and i help you without any cost 09202838700 challenger3_73@yahoo.com
Mar 10, 2009 | Bose 3·2·1 II System
Bose 321 system reads bad disc on all dvds
if will not read a laser lens cleaning disc , then it will need to be opened up and the laser lens will need to be cleaned manually with the cleaning solution and a cotton tip , but do it easy and dry the lens with the cotton tip
if that don't do it then the laser mechanism will need replacing
electech
Nov 27, 2008 | Bose 3 2 1 GSX System
Bose 321
yes as long as IDE cables and DVD player fits it shouldn't be a problem
Apr 24, 2008 | Bose (321GS) System
Bose 321 DVD Stuck Won't Open
This can happen if the disc has been put in upside down accidentally, if both sides are highly reflective (e.g. blank recording discs). If so, you need to get the system to eject the system before it attempts (and fails) to read the wrong side of the disc:
On the back of the Acoustimass module (sub woofer) is a power switch. Use this to the turn the system off and wait 30 seconds. Switch it back on, the media centre flashes up "Bose 321" - press the eject button firmly once as soon as this disappears. If this works, contact Bose with the serial number from the media centre to see if the system needs a (free) software update (a disc they send in the post) - just in case the system is having general disc reading issues.
However, it may be that the drive has failed - it's a mechanical part in a mass produced system so this is not unreasonable, just disappointing. But because you have bought a premium system, the company will rush to help you - call them for a repair and explain you need the disc back urgently. they'll probably arrange an urgent, fast turnaround repair....
Jan 01, 2008 | Bose 3·2·1 II System
Bose 321 DVD System
I love my Bose 321 DVD system, but a few days ago, it started acting weird. I put in a DVD, and it reads - "No Disc".....and I'm not sure why. I cleaned the disc, and I also played a DVD/CD Maintenance kit - I'm not sure what is wrong. It seems like I have a problem within the system - what can I do?
Dec 10, 2007 | Bose (321GS) System
Bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Nov 13, 2007 | Bose 3 2 1 GSX System
Bose 3 2 1 GSX System Logo
95 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
