Question about Mitsubishi VS-7083 70" Rear Projection Television
Mitsubishi TV Model VS-7083
My television is running horizontal lines. It seems that any floor movement triggers the TV to jumps to flickering horizontal lines. If I turn the TV off the problem goes away and if anyone stumps or walks to close to the TV the problem continues. Any suggestions?
  • 934 Answers
The deflection board and/or smps have most likely ring-cracked on one or more components on the board due to heat stress. It's not an expensive fix at the moment, but continuing to operate it this way will place additional stress on components like the regulator and they will eventually fail...
If you're taking it into the shop for this repair also discuss with your tech to do the following per Mits bulletin: APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
Have a great day!
Bill
Posted on Nov 29, 2007
Stk part number for vs-7083
model not listed--sure it is not a VS-70803?
That model uses the 392-040 chips and for that matter you can look inside to confirm the number right on the chips.
Jun 07, 2012 | Mitsubishi VS-7083 70" Rear Projection...
Vs-7083 what stk part number does it need
These STK's work for your model.
STK 391-020
STK 397-010
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
VS-45607
sounds like a defective cappacitor or leaky diode in the deflection circuits. Unless youre comfortable working around the high voltage circuits of a rear projection set, it may be best to call a reputable repair facility that is famillair with mitsubishi products.
Jun 15, 2008 | Mitsubishi VS-45607 45" Rear Projection...
MITSUBISHI vs-7083
What is your source? Antenna, cable, or satellite?
accordianman
Feb 22, 2008 | Mitsubishi VS-7083 70" Rear Projection...
Going down fast
Its definately fixable. Can you post a picture of what your refering to when you say horizontal lines and jumping? Also do you have any soldering ability or troubleshooting experience? Let me know
Jan 12, 2008 | Mitsubishi VS-70707 70" Rear Projection...
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Televison & Video Logo
341 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
