Loose agitator in washing machine
Top loading washing machine (Pope: an Australian brand no longer in production) has developed a loose agitator. It floats up as the machine fills with water and I cannot see any obvious way to make it stay down where it belongs so it can wash the clothes.
The instruction book says I should be able to remove the agitator with a 10mm socket and extension arm, but I can neither see a nut at the bottom of the well (too narrow to shine a light and see at the same time) nor feel one when I probe with a socket on the arm. I certainly can't get the socket head to fit onto anything.
An exploded diagram would probably help – at least I would know what I am trying to deal with – but I can't locate one.
Ideally I would like to see an exploded diagram, but as this is probably not available would be grateful for any other advice on offer!
  • 625 Answers
I checked eBay with no results - sorry.
Posted on Nov 29, 2007
Need to remove agitator to remove lodged medallion
Remove the agitator top cap, and unscrew the mounting bolt part way. Pull up on the agitator by both sides of the rim, then finish removing the bolt after the device is loose. (Keeps you from smacking your face when the agitator comes loose.) Hope this helps.
Oct 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
How do you remove the agitator from a top load washing machine? model VBSR3100WW
Simply pull up very hard it will come loose. You might want to try and old leather belt or strap under the agitator and pull up.
Jul 12, 2009 | Hotpoint VBSR3100GWW Top Load Washer
Lower agitator spins, upper portion does not
The top agitator dogs are wore out and need to be replaces that is what works the top of the agitator
Mar 29, 2009 | Washing Machines
Agitator free spins
Remove the top cap on the agitator and see if the bolt has come loose. If it is not there, the agitator will come loose from the gear case shaft and free spin.
Mar 21, 2009 | Frigidaire FWS833A Top Load Washer
Washer will not agitate.
Pop the top cover on the agitator.
Remove the screw inside.
Remove the agitator and inspect it for damage where it attaches to the transmission shaft.
Feb 24, 2009 | Kenmore 23822 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
During wash cycle the hub nut that is located under the agitator comes loose. It has to be tightened after each wash. GE Profile Top Load Washing Machine
replace the hub nut and the washers under the tubbe sure to tighten really tight if it comes loose again you will need to replace the transmition
Jan 15, 2009 | GE Profile WPRE6100G Top Load Washer
Washing machine won't agitate.
Depending on type of washer, typical top load Maytag, motor turns in opposite direction for wash and spin. Your problem will no doubt be the transmission.
Nov 01, 2008 | Washing Machines
Washing Machines Logo
537 people viewed this question
Top Washing Machines Experts
