Rank: Master
Rating: 82%, 16 votes
Well, you have the 4 ohm dvc kickers, and your amp being stable to 2 ohms doesn't go together very well. If you wire the voice coils in series, and hook the speakers to the amp in parallel, you get 4 ohms, which doesn't use all the power your amp is capable of. If you run the voice coils and the speakers in parallel, you'll drop the resistance to 1 ohm, and probably fry the amp, or at least deal with overheating issues. Better be safe than sorry. You need to run each speaker in series, which means running a positive and negative to each speaker, and a jumper from those terminals to the opposite colored terminals on the second voice coil. Diagram can be seen here:
http://www.kicker.com/06/tech-support/manuals/manuals/02SoloBaricL7manual.pdf That puts two 4ohm voice coils in series, and raises the resistance of each speaker to 8 ohms. Then, you have to run both speakers in parallel to the amp. When you run two 8 ohm circuits in parallel, the total resistance of the circuit is 4 ohms. That means seperate positive and negative wires to each speaker. If it is a mono amp, connect both negatives to the negative output, both positives to the positive output. If it is a multi-channel bridgeable amp, You'll probably connect the negatives to one side output (right for example) then connect the positives to the opposite side output (left for example). If you need to bridge your amp, make sure it is bridgeable, and also that you have the speakers bridged to the proper amp outputs. If not sure, reply back here with the amp model number, and maybe I can help you further.Thanks, and I hope this solves your problem.
