Compaq Presario SR1000T  PC Desktop
Problem for Compaq Presario SR1000T (568657) PC Desktop
SR1000T won't power on
By PopgoesmyJK on Aug 11, 2009
Hi there. I've been having trouble with my desktop for a while. At some point, I came home and tried to turn it on. Only to find that pressing the power button did nothing. Later on that day I tried again and it worked fine. As far as I can tell, when that happens, the green light in the back doesn't light and there's only a soft clicking sound from the back of the tower. I tried replacing the power cord and using different outlets, but it turned out to be by chance whether or not it would turn on. It's been a few months and the power went out a few nights ago. Normally this wouldn't last more than a day, but I haven't been able to power it on since it went off that night.
Is this a serious (and expensive) problem? What should I/ is there anything else I can do?
Solution #1
posted on Aug 11, 2009
Not Rated)
vinhson65
Rank: Guru
Rating: 87%, 57 votes
The click sound is the relay clicking when the power on. The power supply has something wrong so the protection relay is triggered and cut off power to main board. Test fans see if they are stucked and spinning smouthly. Smell if anything burn from the power supply box. Most likely, you need to change the power sup. Good luck
Was this helpful?
Yes
No
Solution #2
Not Rated)
cbacer
Rank: Wiz
Rating: 82%, 30 votes
Hi
Most likely cause is a faulty power supply, however if you have had a power cut then sometimes the mobo is damaged. Get power supply checked first by Tech.
Cheers cbacer
Was this helpful?
Yes
No
Solution #3
Not Rated)
bob_computer
Rank: Guru  Compaq Computer Hardware  Expert
Rating: 87%, 1226 votes
You should download the "SERVICE" manual from compaq and follow the troubleshooting sections in there
Was this helpful?
Yes
No
Popular Solutions for Compaq Presario SR1000T PC
Questions and Unsolved Problems for Compaq Presario SR1000T PC
Do you recommend Compaq Presario SR1000T (568657) PC Desktop?
Answer
Answer
connecting altec lansing speakers. 221 amplified speaker system . trying to connect to my compuer.
Answer
I have a gateway gm5478 model pc with a 22inch lcd gateway fpd2275w monitor(purchased 12/07) for... (More)
Answer
power surge emptied d drive/disc all data gone.computer will not shut down on it's own.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Compaq Presario SR1000T PC...:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
