Question about Mitsubishi VS-60609 60" Rear Projection Television
2- 1 Code detected
I'm Getting a code of 2 -1 = X-ray protect (high voltage ot beam current) can you help
  • Anonymous Mar 09, 2008
    Have the same problem. Was wondering if there is a part that needs to be purchased and/or what would be the cost of fixing this problem
    Genius:
  • 1,139 Answers
This means the anode voltage to your CRTs (RGB) is too high or your controlgrids have failed to slow the electron beam from the cathode down. What you need to do if you do not have electronics experience is to have a qualified TV technician take care of this problem. As a suggestion have him check the HV on the CRT anodes and the voltage doubler which the IHVT goes into. In any event get the set checked and repaired by a qualified technician.
Thank you,
I hope this helps
Shuttle83
Posted on Dec 21, 2007
Mitsubishi hdtv 1080 what are the blinking green light codes
ost models have a self-diagnosis feature to help determine shutdown problems.
To enable this feature do the following....
1) Turn the tv on and then let it shutdown
2) Press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds
3) After 5 seconds the power LED on the front panel will blink a two digit sequence.
This will commonly be one set of blinks followed by a short pause then another set of blinks.
This will repeat around five times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short detected - commonly caused by convergence failure - to repair this check out site for a convergence kit)
2 - 3 = Deflection protect
2 - 4 = Vertical protect
Note: A constant blink on certain models will typically be caused by a fault in the DM model. To repair this check out site a "blinking green light kit"
Aug 05, 2014 | Mitsubishi WS-55513 55" Rear Projection...
Turns off after two seconds when turned on any suggestions please?
Hi
It could be a problem of cold solder joints, or solder joints on the main board which have cracked over time due to thermal expansion and contraction of the circuit board. Repair is to find and reflow the cracked joints. You may want to consider hiring the services of a reputable repair professional to deal with getting your set back into normal operating condition.
However TV's attempt to protect themselves from damage by shutting down. Your unit has three main ways to protect from damage.
SHORT PROTECT
The TV monitors various DC voltage supplies. If one of the supplies is missing. The TV shuts off.
X-RAY PROTECT
The TV monitors excessive high voltage and beam current. When the TV detects that one of these is too high the TV shuts off.
OVER CURRENT PROTECTION
This will activate if excessive current drain on the 130 volt supply line. If the TV detects this supply line is too high the TV shuts off.
Most units made in 1999 have a diagnostic mode to help determine the cause.
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 17, 2012 | Mitsubishi Televison & Video
My TV shuts off as soon as I turn it on...What is causing it to do this??
When it shuts off. Try doing what's called a self-diagnostic test. As soon as the television shuts try these steps.
Pressing on the front panel's 'INPUT' and 'MENU' buttons at the same time, and holding for 5 seconds, activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
-The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
-The flashing then pauses for approximately 1/2 second.
-The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
-The Error Code is repeated a total of 5 times.
-Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnostic Code Description
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Apr 08, 2010 | Haier 20" TV/DVD Combo
Keeps shutting off
times.
Warm regards,
BearWeb
Will not turn on
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
times.
Self Diagnosic Code Description
Jun 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv willnot turn on
times.
Will not turn on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Oct 06, 2007 | Mitsubishi VS-50607 50" Rear Projection...
No power
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) Hope this helps you!
Sep 14, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Vs-5043 No Filaments lighting on any of the guns
Yes you have no High Voltage, and you have filaments if you look at CRT's and they are dimmly lit on neck of tube.:::::This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB
Jan 15, 2007 | Mitsubishi VS-5043 50" Rear Projection...
VS50607 Mitsubishi
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.....
Sep 24, 2006 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-60609 60" Rear Projection Television Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
