Sounds like the PS button might be broken or jammed. With a knife, try unlodging the button, but be careful you don't damage the PSP. If this doesn't fix the problem, you might want to phone up sony support.
go to ur M33 Recovery Menu.(it can be access by totally turning of your psp-holding the power button up...and then turn it on again but hold the R button.. It should appear as it turns on..)
go to the configuration and press Xbutton..
browse and go to UMD Mode and
check if it set to <currently: M33 Driver -NO UMD>if not, just press x until it appears...
after that exit in that menu...games should play after that setting..i have encountered 8 psp's with that kind of problem...
trust me you dont want to go to a service center unless you can have a solutions on the internet...coz it will cost you 500-700php
1. Set “UMD Mode” to M33
driver NO UMD The PSP firmware version was 3.71 M33 but is also tested
with higher versions like 3.8 M33. These firmware versions should have
the UMD mode to M33 NO UMD. To set the following you need to
go to the Configuration Page. To go there you need to: i.Turn off your PSP ii.Press
and hold the R button. While doing that slide and hold the power
button up. This would turn on your PSP. You should hold until the black
screen appears saying “M33 Recovery Menu Configuration” iii.If
the PSP just turns on to the normal menu, just repeat the two steps
above. 2. Set “Use VshMenu” to Disabled. It is also in the configuration page. Use the steps above
and you should be able to find it. Now after these two steps, if you continue no further, your
PS would run faster – but only for the menu screen. The menu would be
fast and really responsive. However, try playing a game. You would
notice that loading is still slow and the gameplay is still played in
slow motion
3. Set the CPU speed to
Default. Now this is really important. The CPU may not really be
used when playing music or in the menu screen but its very important
when you play games. There are two settings you need to adjust. Speed in XMB and
Speed in UMD/ISO. For us normal users we just need to set these two to
“Default”. After this, your PSP should be running ok. However, I
recommend that you do another step which would also help the performance
of your PSP. 4. Free up memory from your Memory Stick. You can do this using two methods. One, you could connect
your PSP to your PC using a USB cable. Two, you could remove your memory
stick and use a card reader. I prefer the second method but you may use
any of the two.
Method Two: Remove your memory
stick and use a card reader. Freeing up memory is easy, if
you know what files to remove. As my friend is not really using her PSP
for music and videos, majority of her files are game files. What she
does is that she just puts games that she really plays. I recommend
doing the same for your PSP. Game files are located at the folder named “ISO”. The game
files have a .CSO file name extension. You don’t need to delete them.
Just transfer them to your hard disk. That way, when you want to play
them again, you just have to transfer them back to your memory stick. But if you have music and video files that take up much
space, I recommend that you look into those first. Normally you would
like to have at least 500MB of free disk space. You’d need the space for
your game saves. My friends have done the steps above with ease and have
solved their slow PSP problems. Most of them, if not all, had to do all
four mentioned above. The first three usually solves the problem.
I haven't got a tv which is good enough for the psp componets cable. But as sony psp manual says, http://manuals.playstation.net/document/en/psp/current/settings/index_videoout.html you probably need to setup your tv for the correct display type, not only on your psp, BUT ALSO YOUR TV SETUP!
