Question about Apple iPod MA446LL/A MP3 Player
Apple Ipod Video
I have kind of the same problem, I was listening to music, I got busy, so I "pause/lock" my Ipod, now I can't unlocked. When I move the lever back to "unlock" the "lock" still shows in the screen and I CAN'T do anything.
If you have an answer to this issue, could you please e-mail it back to [email protected] PLEASE :)
THANK YOU........
To reset an iPod with a Click Wheel, including: Apple Ipod Video - ipodnano3.jpg icon_ipod_5g.gif ipodnano2.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Posted on Dec 20, 2007
2 Suggested Answers
SOURCE:
ctf1800
  • 4402 Answers
SOURCE: ipod video "lock"
This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your iPod is associated with, do this:
1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize
Posted on Dec 21, 2007
How to remove the screen lock
Where did all the lovely music go? When your iPod Classic freezes up, you may need to restart or reset the iPod. Follow these steps to reset an iPod Classic, or in fact any iPod with a Click Wheel.
Make sure the iPod Classic isn't simply paused or locked. Check the screen for a lock symbol. If you see a lock, unlock the Hold switch. You should be back in business. Put the iPod on a flat surface to stabilize it. Slide the Hold switch on, then slide it off. Hold down Select and Menu together for several seconds with two fingers. Make sure your finger isn't touching the Click Wheel. When the Apple logo appears, release Select and Menu. If the iPod Classic doesn't reset, repeat the above step. If that still doesn't get your iPod Classic to restart, plug the iPod into a power adapter or a computer and see if it starts up.
http://support.apple.com/kb/TS1382?viewlocale=en_US(URL)
Apr 17, 2013 | Apple iPod classic MP3 Player
How to unlock your ipod nano from it be locked to listen to music
In the Apple Support Site, Apple notes that the "Screen Lock" function:
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally -- not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with itunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Nov 05, 2009 | Apple iPod nano
I dont know how to unlock my ipod
bye lock do u mean hold? if so, on the top of your ipod flip the switch to the side without the red light
Jun 30, 2009 | Apple iPod nano
THere is this password/code to unlock
If it is simply locked, you can slide the hold/lock switch.
If it's asking for a password, and it's not 1,1,1,1 , then you will need to open iTunes and do a system Restore on the iPod - it will unlock the iPod, but it erases all of your music, so it will have to be reloaded.
Mar 30, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod nano
to put your own music on it you will need to download the latest version of itunes
http://www.apple.com/itunes/download/
then create a library of music in itunes and plug your ipod into the computer and sync your ipod with itunes to download the music onto it.
If the ipod has music on it already then you can just scroll through the library on it to listen to the music, if it is not music you want, then follow the above advice and you will be able to copy your own music into itunes then sync it with your ipod.
Hope this helps
Oct 31, 2008 | Apple iPod nano
Ipod security code
Of coarse we can Help okay the Best Software to save your music and put it back to your Computer it is called (Transfer My Music) they sell it at Best Buy or Fry's Electronic Store. Please check your Local business. We can definetly help you on this repair. Please call us at 661-619-5928 or email us at [email protected] and we will definetly help you out.
We look foward to your business and also Repairing your Broken iPOD
Thanks again
ipodrepairz
Sep 21, 2008 | Apple iPod nano
Ipod nano screen and music keep locking up
Please dont take your ipod along with you. May be it doesnt like to cme out for running
Jul 14, 2008 | Apple iPod nano
Operate an ipod
To get it unlocked: Find a black (or silver) oval switch on it. Move the switch to the left and orange will appear. Your ipod will be unlocked.
To scroll through things: Move your finger around the black circle.
To select something: Press the center black button.
To shut your ipod off: Hold down the pause button (button on bottom of scroll circle) for three seconds. Then switch the hold button to the right to lock it.
To pause something: Press the pause button (button on the bottom of the scroll circle).
I hope my solution was helpful. Please rate it.
Jan 17, 2008 | Apple iPod nano
Ipod video "lock"
Nov 29, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
63 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Parshiv Luthra
Marvin
Marvin
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
