Question about Samsung DLP HL-P5663W 56" TV
Samsung 56" shuts off after 5 or 10 seconds see a checker board image before shutoff
My Samsung 56" shuts off after 5 or 10 seconds. You can see a checker image on screen before shutoff.
    Scholar:
  • 87 Answers
When the set shuts down you need to see what lights are blinking. For example: Timer/ Temp/ lamp on the front panel. You should also count the number of times they blink and the sequence. Most DLP`s give an error code alerting the technician to check the balast, lamp, or fan etc. for malfunctions. Unfortunately I can not tell you exactly what is wrong given the current information. Howrver, the last Samsung I repaired for shutting down had a bad light engine.
Posted on Nov 29, 2007
Fridigdere up rite stackable dryer keeps beeping and shuts off after running for about 5,10 seconds,what do I check,?????
Google the model and codes. You should find instructions in how to to retrieve the codes and that will point you in the right direction.
Oct 14, 2016 | Dryers
My Black & Decker d2020 iron immediately goes to auto shut off and will not stay on.
test the 1) fuse heat and replace it
2) test the board if there are voltage , if there are the board can be faulty or repair.
3) see your instruc. manual go to the section troubleshooting and see what is wrong.
God bless you
Sep 30, 2012 | Black & Decker D2020 Iron
Samsung 56" DLP
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Televison & Video
The timer and standby lights are blinking at the same time. TV turns on for a few seconds then turns off. Both fans turn on when the TV turns on and off when the tv turns off. Any idea what might be...
The problem if you television is in the power section.The power suppy shutoff because they have leak parts like capacitor and transistor.Its better to troubleshoot the power supply.Thanks
Jul 09, 2011 | Samsung DLP HL-P5663W 56" TV
I was in the middle of a movie and my room started to smell like burnt popcorn then the tv shut off and it would not stop trying to come on and off every 40 seconds the picture would come on but just for a...
It sound like you have a power supply fault caused by a display failure.
Without a service manual and test gear, I don't think there is much likelyhood of an effective repair.
Contact Samsung for a dealer in your area is my advice.
Hope that helps.
Nov 22, 2010 | Samsung 56" Slim-Depth LED DLP HDTV
My samsung dlp shuts off after about 15 seconds
3 years its about that time to change the lamp. Call local repair shop for lamp availability.
Jan 10, 2010 | Samsung DLP HL-P5663W 56" TV
My 56 inch tv shut itself off and will not turn back on, all 3 light lower right are blinking, any answers?
You need to change the lamp. This tele doesn't have a color wheel so that leaves the lamp or the power board. Try the lamp first, it is the most likely problem.
Jul 21, 2009 | Samsung HL-S5679W 56" HDTV
Samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Jan 10, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
510 people viewed this question
Jerry Greenberg
Jerry Greenberg
