Question about Linksys Wireless-N WRT150N Router
I cannot connect to my new WRT150N router
So far I've tried two types of wireless cards, and two other wireless devices and everything has failed. I shut down all forms of security, reinstalled all the software and hardware 2 times; followed all connection directions for using both Linksys and Windows XP but nothing works.
I have not tested the wireless cards or devices to connect with other wireless networks, but I am relatively certain they work. I have had them acknowledge the network I set up, but everytime it says unable to connect.
  • 556 Answers
Lets start with the basics. First do you have a computer with an ethernet port for a wired connection? If so connect it to the router and attempt to access the internet. If this works we have eliminated the ISP connection and need to address the wireless configuration of either the router or the adapter or both. I will need the version number of the router which probably appears on a label on the bottom of the device to get access to the proper users guide. I do not have one of these models specifically however on reading the specs it mentions that it works well with B and G wireless cards -- there is a possibility this device will not work with A band cards -- we will confirm this later. Please provide the model number for wireless adapter so we can research them if needed.
Posted on Dec 06, 2007
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
I am trying to connect a wrt150n wireless linksys router to my dsl. I am using a desktop windows 7 and laptop windows vista. Please help, I have tried everything but it just does not want to work.
unplug everything, including ethernet cables. then work in this exact order.
if you get a wireless signal and no internet, plug a computer in into the router in one of the available ports and check for internet. If no internet, unplug everything and test the modem without the router. If internet available without the router, then follow these instructions
  1. plug phone line into modem
  2. plug power into modem
  3. wait for all lights to become steady
  4. plug ethernet cable into modem
  5. plug other end of same cable into port labled "internet"
  6. wait for lights to become constant on both router and modem
  7. check your wireless device for wireless service.
if you dont get a wireless signal at all, plug your device into the rear of the router and type 192.168.1.1 in the adress bar
the password and username are both "admin" or simply leave the password blank if that doesn't work
navigate to the wireless option and turn on the wireless transmiter.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Dec 01, 2010 | Linksys Wireless-N WRT150N Router
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
Router keeps dropping connection
Solution for wireless dropping issue or connectivity issues
*Change channels on the router from1,6,11 or 9(rarely works) *Change Channel width 20 or 20/40 MHz *Keep other radio signal emitting or wireless devices away as possible *Change security types *Change Antennas position *Upgrade the firmware
May 15, 2010 | Linksys Wireless-N WRT150N Router
Wireless-N WRT150N Router: I am not able to connect to internet wireless usii...
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
May 06, 2010 | Linksys Wireless-N WRT150N Router
Just purchase a Linksys WRT150-N Wireless Router. I can't connect to the internet using the connections suggested
First, check if the devices that you're trying to connect this router supports wireless encryption protocol-N (802.11N). If the devices do support then enable WLAN-N standard by following the manufacturers recommendations.
Then try connecting.
Oct 17, 2009 | Linksys Wireless-N WRT150N Router
I am installing my new wrt150n router and no internet
Turn off modem and router. Connect router to computer. Turn router on. Connect router to modem. Power up modem. When it discovers the modem it will assign to it the new IP address.
Hope it helps.
Sep 25, 2009 | Linksys Wireless-N WRT150N Router
Wireless network using usb modem
First thing that you have to do is to check if the wireless light on your linksys wrt150N is lit. If it is, then that means that it is emitting wireless signal so you can connect wirelessly.
Then, install your verizon usb mobile broadband card on your desktop. When you plug it to the usb port, a pop up balloon would show on your page which would say FOUND NEW HARDWARE. you could click on it and choose the CD-drive to install OR you can run the cd and have it install on itself.
After installing the usb, try to connect to your wireless network. Start > Connect to > and then click on the name of your wireless network.
Apr 08, 2009 | Linksys Wireless-N WRT150N Router
Can't connect wireless to WRT150N.
Your hardware might not be compatible with eachother.
Mar 17, 2008 | Linksys Wireless-N WRT150N Router
WRT150N Linksys... my laptop will see it as a G signal router, and won't be able to connect.
as you have said, configure your router , in a g standard, so that your laptop can access it, becos, your router is emitting, n signal and youy wireless card is capable of receiving only g signals, so reconfig your router, upgrade the latest firmware in the router and check..
Dec 18, 2007 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
90 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
