Hitachi EC119SA Twin-Stack Air Compressor with Control Panel and Couplers
Problem for Hitachi EC119SA Twin-Stack Air Compressor with Control...
Hitachi twin stack problem.
By HitachiBoy on Aug 11, 2009
I have a Hitachi air compressor EC119SA twin stack. Yesterday it filled up and after shooting a few nails it tried to run again. It sputtered and then tripped the reset switch. Now when Plugged it all it will do is hum and trip the reset. I removed the non return valve and tried to run it... and it still just hums. Ideas?
Comments:
Aug 21, 2009
- Well, after taking pretty much the whole compressor apart, I wiggled the wire on the thermal reset switch and now the compressor runs like new. I tried wiggling wires before tearing the compressor apart but couldn't reach there. If anybody else has a buzzing problem like mine I would highly recommend checking the wiring before taking the compressor in for service.
Best Solution
posted on Aug 12, 2009
Helpful)
digritz
Rank: Guru
Rating: 94%, 162 votes
You stated that the compressor started up fine. I'll assume it reached it's max psi then cut out. Then upon reaching it's cut-in psi the motor ran slowly for a few seconds, then kicked off. I also assume you mean check valve when you refer to the non return valve.
If this sounds about right then. The first thing I would do is bleed out all the air from both the tank and the pump supply line leading from the pump head to the tank's check valve. You can do this by simply loosening the fitting that attaches the line at the head or the check valve. Once done try running the compressor again.
The purpose of this is to check the unloader valve. This valve bleeds off the pressure that remains in the compression cylinder and the supply line up to the check valve. When functioning normaly it will bleed off this pressure once the motor shuts off. If it is not working correctly then when your compressor starts back up (once it is already been filled) the piston will be working against a psi close to the max psi.
If the problem reoccurs only after the compressor has reached it's max psi, then the unloader valve is most likely the problem. If however it will not start up at all even after a complete bleed then it has to be something internal to the pump and\or motor.
Please try this and let me know (or repost) your findings.
If it's the unloader valve I should be able to explain how to repair this valve.
Good luck.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Good info " - HitachiBoy
Popular Solutions for Hitachi EC119SA Twin-Stack Air
Questions and Unsolved Problems for Hitachi EC119SA Twin-Stack Air
Do you recommend Hitachi EC119SA Twin-Stack Air Compressor with Control Panel and Couplers ?
Answer
Answer
I have a mastercraft air compressor. Need to have the motor repaired but we dont know the... (More)
Answer
sudden air leak from the manifold of my P-C 6 gal. air compressor
Answer
I have a FX Air Compressor for Air Rifles. The compressor needs to have the seals replaced. The... (More)
Answer
where can I get a replacement air filter assembly for a UST 1106C compressor. Plastic housing... (More)
Answer
Hitachi hdc-57ies coming up card protected sandisk sdhc 4gb inserted???? help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air... Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
