Question about Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster
Toaster smoked will a new toaster smoke when you first use it
Where can toaster smoked - spellcheck.gifi get the maneal to use it
Posted on Feb 02, 2008
    Scholar:
    New Friend:
  • 67 Answers
Possibly, especially if there is any grease or oil on conducting elements. I have had devices that were packed in styrofoam get small pieces down inside the devices so check for them first if possible. Before you trust the device, plug it into a bathroom or bedroom receptacle that is equipped with ground fault detection. Plugging it in outside on a dry concrete or sandy area and running a loaf of bread through it should tell you if it's ok. The birds should eat the toast it makes
Posted on Nov 30, 2007
SOURCE:
Slight smoking, smells like melted plastic or paint
I would have said the new is smelling , but don't run the risk here, take it back and get another, unless you want to call there help desk.
Jan 18, 2013 | Kitchen Appliances - Others
Why is there smoke?
Kindly switch off the TV, switch off power, and remove plug. The TV needs servicing by a qualified service technician.
Aug 23, 2012 | Toshiba REGZA 37RV530 LCD TV
Hi, The dial on our Dualit toaster gets stuck on
The timer can be rplaced by any good handyman. You can get a new one on ebay there are two types make sure you get the right one. Replace it before someone forgets to shut it off and the toaster smokes up the kitchen. Its a common problem with the dualits but the switch is not cheap and you can only get it from England. The good news is the replacement seems to be better made than the original
Jan 09, 2011 | Dualit 20084 2Slice Toaster
When the oven is on for a couple of min. it makes a bang sound
Probably is the metal heating up and expanding. Does everything still work? Your not smelling any smoke are you. If it still works fine and your not seeing any smoke or smelling anything burning it probably is OK. Does it do this everytime you use it? The sheet metal on the outside and inside can expand and if it is crimped at all it will make a noise when it heats up and expands. I hear this a lot where I work, we deal with extreme temperatures and when metal heats up it expands and pops sometimes!
Nov 15, 2010 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
My smoke detector periodically goes off when I am cooking although no smoke is detected.
You most likely have an ionization type detector which detects ionized particles of combustion. This type of detector does not look for smoke density but for ionized (excited) molecules in the air. Water vapor from cooking can and will set off an alarm. Burning a piece of toast in the toaster with little or no smoke will also cause a false alarm. Try moving the smoke detector further away from where you cook. This will most likely solve your problem. Hope this helps.
Jun 26, 2010 | GE Security Simon 3 Wireless Home Security...
Paula Deen toaster egg poacher caught on fire
The same thing happened to me today and I've been searching the internet for other complaints. It happened exactly as you said, I heard a buzzing noise and went to see what it was and it was the toaster- smoke started to come out from the top. Please report your experience to the CPSC! http://www.cpsc.gov/index.html This thing needs to be recalled!
Jul 04, 2009 | Back to Basics TEM-500 Egg & Muffin...
Just purchased a new toastmaster COV760B and it started smoking a lot when I plugged it in to pre-heat. Is this just the "newness" burning off or is this abnormal? Just want to make sure I don't have a...
Smoking is just the oils from the manufacturing process burning off! If it smokes longer then fifteen minutes at first start up you may need to replace thermostat! but I think you will be ok!
Please rate my response !
Jan 07, 2009 | Salton COV760B Toaster Oven with...
Back to Basics TEM-500 Egg & Muffin 2-Slice Toaster Logo
235 people viewed this question
Top Back to Basics Kitchen Appliances - Others Experts
ellenskitche
Vitally Alcher
ray gallant
ray gallant
Are you a Back to Basics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
