Bugaboo Cameleon Jogger Logo
Anonymous Posted on Aug 11, 2009
Hi I cannot get the handbrake lever to stay on it pushes forward,the wheels are braked but is poops back as soon as I let go can I fix it?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
685
Points
Check for solutions under the heading brake...I had the same issue and followed some solution to take apart the brake handle and it totally worked. (I'm not handy remotely but was able to complete the task in less than 10 minutes).
Good luck.
It sounds like you are having the problem I had...look for the solution that tells you to take the 2 screws out of the side of the lock handle.
Testimonial: "Thankyou! All fixed and ready to roll again! or not... now the brake works!!"
2answers
Hand brake adjustment on KIA Carnival
The Kia Carnival has drum brakes on the rear and they are self adjusting. They can however be adjusted by working the handbrake lever up and down a few times, if it has not been previously adjusted by using the cable adjustment, then this will probably not work, and it is something I come across quite a lot. if all this fails, then it is a matter of taking the wheels off and removing the drum. firstly check the position of the handbrake actuating lever (its connected to the cable) with the handbrake off (wheels chocked of course) the lever should be as far back as possible to the brake shoe, if it isn't check that you have a little bit of slack on the cable and it is not seized if not adjust the cable off a little so the levers return fully. if you look you will see the self adjuster you can turn the notched wheel a few clicks and then put the drum back on. make sure it is not binding when you turn it (a slight rub is ok) tap the drum (top, bottom, left, right) to centre the shoes (this is important because it will give false adjustment if you don't). once you have done this to both sides, double check both wheels are still running free. replace wheels a try handbrake, it should be ok now. Check how many clicks you need to pull the lever to apply brake and adjust the cable just enough to remove any slack in it, NO MORE. Warning! DO NOT HIT THE DRUM HARD AS IT WILL CAUSE FRACTURES. I hope that has been of some help to you.
2answers
How to adjust parking brake on 1993 chevy lumina ?
  • Adjustments
  1. Apply service brake pedal three times with a force of approximately 175 lbs.
  2. Fully apply and release parking brake three times. Full application may require two pedal strokes.
  3. Raise and support vehicle, then mark relationship between wheel and axle flange.
  4. Check parking brake pedal assembly for full release as follows:
    1. Turn ignition switch to On position.
    2. If ``Brake\'\' lamp is illuminated, operate manual brake release and pull downward on front parking brake cable to remove slack from pedal assembly.
  1. Remove rear wheel and tire assemblies, then install two lug nuts to retain each rotor assembly.
  2. If two parking brake levers on both calipers are not against lever stops on caliper housings, check for binding in rear cables and/or loosen cables at adjuster until both left and right levers are against their stops.
  3. Tighten parking brake cable at adjuster until either the left or right lever begins to move off the stop, then loosen adjustment until lever moves back barely touching stop.
  4. Operate parking brake several times to check adjustments. A firm pedal feel should be obtained by pumping pedal two full strokes and rear wheels should not rotate forward when parking brake is fully applied.
  5. Install wheel and tire assemblies, aligning marks made in step 3.
I have a 20" inch girls kent trouble bike. How do I take the rear wheel off?
remove the coaster brake lever bolt. This is small bolt that holds the coaster brake lever to the left side chain stay. There will probably be a strap wrapped around the chain stay with bolt going through the strap and the lever. This usually requires a 10mm wrench (sometimes it is 8mm) for the nut and a Phillips or flat head screw driver (some times it's another 10mm bolt head).
The axle nuts are usually 15mm nuts. Loosen these (they usually don't need to be removed all the way) and push the wheel forward to put some slack in the chain. Lift the chain off the rear cog and you will be able to pull the wheel out of the drop outs.
To install, slide the wheel into the dropouts, put the chain back on the cog, pull back on the wheel and tighten the nuts finger tight. Reinstall the bolt through the coaster brake lever and then tighten the axle nuts, pull back on the wheel while tightening the nuts so the chain is tight. Then tighten up the coaster brake lever bolt. (if you tighten the axle nuts first, you won't be able to move the coaster brake lever into place to get the bolt in)
Aug 18, 2014 • Cycling
2answers
How to adjust handbrake on2001 mondeo
General advice:All handbrakes rise adjust from under the car,very rare behind the handle lever.Worning:Handbrake adjustment need to balance so u need to know if each back wheel brakes even,in order to see that u may have to jack the car and count the rising clicks on handbrake lever to see at what point the wheel stops (u must rotate the wheel by hand (and maybe ask for a friend to brake),with quite some force.Inspect also the interior component (in the back drum if apply,if on disc there is no need)Empiric :by driving at low speed on even road and handbrake hard,the marks of each wheel on the road must start +/- at the same point.Warning:This is dangerous manouver,the car may drift,do not steer while braking,if not shure,better take it to a dino test.Tip:if u tune eack whell at the max brake open position,the handbrake balance,and from there u can adjust the hight of the lever rise by loosing or tighten the cable.Hope u deal it.Cheers.
Handbrake light stays on
Hi
If you have checked your brake fluid level is fine try pulling off the plug that goes to the lid of your brake fluid reservoir and plug it back in just to check for a bad earth as usually a faulty handbrake switch will make the handbrake light flash and beep as a safety warning to let you know you have left your handbrake on
I hope this helps Nick
I am going to hope these two items are related.
First the handbrake.
On most cars, it works like this. ( Wish I could say that for VW !)
The handbrake lever or pedal has a very small switch, about the size of your little finger, located in a place near the lever or pedal so that, when you push the pedal or pull the lever, the little switch has a button inside it that is released to come out, and that turns on your light, telling you the brake is on.
It is a "push button" switch.
When you release the pedal or the brake lever to normal position, the button is pushed back into the switch turning off the light.
I suspect you have a lever between the seats.
It will be surely hard to find the switch, as it likely is down inside the console.
If yours has the pedal under the dashboard, it is much easier to find, as you should be able to see it way up under the dashboard near the top of the emergency brake pedal.
The switches are usually only a few dollars, unless you go to a car dealer, and the labor can be high.
Oh yes, sometimes the switches are made of cheap plastic, and they can actually break or fall out of their socket !
I think the beeping may just be an audible reminder of the switch problem.
Be Blessed.
Parking brake stuck
footbrake kind or handbrake lever.. spray wd40 on the cable where it enters the sheath and work it on and off.. also check the cables where they are located near the back wheels and spray these also.. they rust up and stick ..lever style e-brake has a button on the lever that must be pushed in to release..if jerked up to hard by a strong arm it will be tough to release it.. calls for 2 hands to pull up and push the button at the same time..foot brake requires pushing down while pulling the hand release and see if it works.. repost please..
Adjust handbrake 94 libero
  • Remove the center console covering the parking brake lever. Locate the parking brake lever between the drivers seat and the front passenger seat. Put the parking brake lever in the lowest position.
  • 2
    Turn the cable adjuster locknut to make the nut loose. Find the nut at the base of the parking brake lever.
  • 3
    Raise your GT rear wheels using a jack and support the rear wheels using jack stands. Remove both rear wheels using a tire iron to loosen and take off the lug nuts. Take off the tire from the rods by hand.
  • 4
    Get underneath the car and remove the rubber hole plugs from the brake rotors. Locate the rotors on the underneath inside of the wheel wells.
  • 5
    Take off the brake calipers with a screwdriver, but do not disconnect the brake fluid lines.
  • 6
    Use a pry bar to push up on the parking brake self adjuster wheel. Locate this next to the brake caliper and it looks like a star wheel. Rotate this wheel until the rotors will not turn.
  • 7
    Turn the adjuster wheel five notches in the opposite direction. Reinstall the calipers and wheels. Lower your GT using the jack and remove the jack stands from the rear wheels.
  • 1helpful
    2answers
    My handbrake needs adjusting in my Toyota Corolla 1994. Can u please explain how this adjustment is done.
    Hello, My usual Brands are Ford products, but Foreign cars usually use simple, less expensive ways to do things. Assuming the brake pads are good, there should be a cable connected to the handbrake. You would usually pull the handbrake up to engage about 1/4 the way to engagement and lock it there.
    Then you would go underneath the car and find the cable that stretches from the handbrake lever to a juction with a second cable. There should be an adjusting thread somewhere at this intersection.
    With the rear wheels off the ground, you would tighten the nut on the threads of the handbrake cable until you hear rubbing in the rear brakes. Then get inside the car and pull back on the handbrake lever and you should not be able to move the rear wheels with the handbrake set. You then release the handbrake 100% and the rear wheels should turn mostly without noise.
    Now if you can not find an adjustment nut under the car, it is possible the handbrake adjustment nut is under the handbrake cover/boot inside the car. Still use the same process of setting the lever 1/4 engaged and tightening the threaded cable until the rear wheels start dragging.
    I hope this helps you.
    Top Bugaboo Baby Gear Experts
    Jennifer Rock
    Jennifer Rock
    ZJ Limited
    ZJ Limited
    john h
    Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
