Question about GE JTP45 Electric Double Oven
Oven Clock The clock works but the digital display is very dim. I cannot locate any instruction to adjust the brightness of the display. I assume that the "fix" will require replacement of a part; however, I have encountered a problem with identifying a replacement part. The Model Number on the oven is JTP45W0W2WW but that number is not recognized by any website search function. I have tried searching by replacing the "zero" in the model number with the letter "O" but that does not work either. Do you know how to fix this problem or find the part number of the defective part?
  • 290 Answers
You are correct about replacing a part. there is no adjustment for the brightness. The control board will have to be replaced.
To look up parts for your oven you have to drop the 0 from the number. Try JTP45WW2WW. No one at GE has been able to explain to me why they put the zero in the model number when it is not used to look up parts. But if you leave it out on a warranty claim, they will reject it because the model number is incorrect. Go figure.
I looked it up on sears.com and repairclinic.com.
The part number for the original board is WB27K5301, but that will change to WB27T10292 that has replaced the original.
Post back if you have any questions.
Thanks/Mike
Posted on Nov 29, 2007
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Hi i have a de-dietrich dod338 oven but ive found the light on the clock is very dim yet if i have a power cut and when i reset the power trip again its bright but as soon as i try to set the time it goes...
i had this problem also - it is the timer assembly. you can replace the timer assembly as a whole, or if you're useful with a soldering iron, replace the capacitor which is right next to the digital display. the display gets warm and this gradually breaks the capacitor. I replaced this - it was about £3 from rs components (the capacitance and other info is printed on the side of the capacitor). Hope this helps - i bought a replacement main board and clock assembly ( which got lost in the post so i tried to fix it in the mean-time while the replacement was sent out.) obviously don't do this fix if you are not confident, but that was the fix for my problem which is the same symptoms as yours.
Dec 14, 2009 | Ovens
F7 shows on display and display getting dimmer over months
Dim display is TOTALLY independent of F7 error.
The display will dim as the display board capacitors wear out - due to the heat. Replace the capacitors on the display board (see my other posts) and your be able to see the F7 error code as bright as can be!
Jul 16, 2009 | Thermador SC302T Electric Double Oven
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Temp/clock display faided
its the display theat is fading away. I've haad meter's do the same thing after awhile and there's nothing you or I can do. Thanks for using Fixya
Dec 23, 2008 | Thermador SC302T Electric Double Oven
Lighted clock and controls intermittently not working. Oven still heats
HI thanks for the question. its a common problem with the clocks. first it goes a little dimmer. then a little more till it goes so dim you cant even see the temperature that you have in the oven. the clock has to be replaced. or. buy a cheap oven thermometer. and hang on the middle rack, and adjust the temp setting to match the oven temp . save a lot of money this way. thanks. please rate my answer. thanks
Oct 09, 2008 | Jenn-Air Ovens
Clock problem
had same problem but didn't fix it because i don't use the clock. after a few months it got worse, can't set the time (clock always flashing) so the oven doesn't work.
Jan 21, 2008 | De Dietrich DOC310 Electric Single Oven
GE JTP45 Electric Double Oven Logo
444 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
