Question about APC Smart-UPS 700INET (SU700INET) UPS System
No Power on output
I have no power on the output of the ups. Pressed the breaker reset switch on the rear and not able to turn on with the front power switch.
Does the batteries need to be charged prior to use? I have about 7 volts on battery (no load) when battery is removed.
Any help would be great
Thanks
  • bideabsamuel Dec 14, 2007
    i hav 12.8 volts on the battery but it is still not working. the moment you connect the AC outlet to the main power source you will hear a shot beep and all the leds will flash and go. secondly when you take off the AC outlet cable off and press the power button the same thing will happen. thirdly when you plug the cable to the AC and press the power button there will be no sign of coming. please help
  • mrbob703 Mar 20, 2008
    Same problem. I plugged in the unit after it was sitting for a couple months and it doesn't seem like it is getting any power. Lights aren't on, pushing curcuit breaker didn't do it or the test buttom. What's left?
    New Friend:
  • 159 Answers
Check circuit breaker if it work properly change battery
Posted on Apr 05, 2008
SOURCE:
Is there a fuse for the window switch
Which window switch ? RT DOOR CB-circuit breaker , do you know what a circuit breaker is ? 25A (System power for right rear window)
LT DOOR CB 25A (System power for left rear window
The power window system will operate anytime the retained accessory power (RAP) system is active or when the ignition switch is in the ACCY or ON position.
The DDM contains 4 power window switches which are integral components. Closing any of the normally open, rocker type switches provides the DDM with a request for power window operation. The switches for the 2 front windows have 3 positions Up, Down and Express Down, while the switches for the rear windows have only 2 positions, Up and Down. Each of these switches and their positions is a direct input into the DDM. Upon receiving a request for power window operation, the DDM, transmits a class 2 message indicating the switch and it's changed position.
The PDM contains a single power window switch that is an integral component. Closing of this normally open, rocker switch provides the PDM with a request for the front passenger power window operation. The switch for the front passenger window has 2 positions Up and Down. Each of these switch positions is a direct input to the PDM.
The 2 rear passenger doors have there own switches. Each of the switches contain a power window up and down relay. A switch activation alone can control the up and down functions of the rear windows. However the BCM, upon receiving a class 2 message from the DDM, can control the set of relays which will activate the rear window motors.
The power window system consists of the following components:
Driver door module (DDM)
Passenger door module (PDM)
Body control module (BCM)
LR power window switch
RR power window switch
Window up and window down relays in each of the rear passenger window switches
Window lockout switch
Reversible power window motors in each of the doors (circuit breaker protected)
LT DOOR CB 25A (System power for left rear window)
RT DOOR CB 25A (System power for right rear window)
If you not sure about any of this I suggest you take your vehicle to a ASE certified repair shop .
Oct 08, 2015 | 2002 Chevrolet TrailBlazer
Where is power window relay located 2001 buick regal
There is no relay for power windows !
Power Window System Components
Driver window switch
Front Passenger window switch
Left Rear window switch
Right Rear window switch
Window regulator motors in each of the doors
PWR WINDOWS PWR SUNROOF Circuit Breaker 30A
When the ignition switch is in the RUN or ACCY position, or Retained Accessory Power (RAP) is enabled and the lockout switch is disengaged, battery positive voltage will be available at the passenger window switches. When an individual window switch is pressed in the down position, battery positive voltage is applied to the window regulator motor causing that window to open. When the individual window switch is pressed in the up position, voltage is applied to the window regulator motor in the opposite direction causing that window to close. The return path to ground is supplied through the inactive control circuit being normally grounded through the driver window switch.
Jul 28, 2015 | Buick Cars & Trucks
Robinar Cooltech 342000 - on start up stops on the "Initalizing System" screen. Is there a reset procedure available?
You can try the following : 1# Check main 15 amp circuit breaker (located on back of the machine), reset the circuit breaker. If breaker tripped again after reset, the circuit breaker need to be replace.
2# Verify line voltage is present at input of main power switch & output at switch turn ON. If line voltage is not present at power switch input, check connections between power switch and AC plug. If line voltage is present at power switch input, but not at output with power switch turned ON, replace power switch.
3# If all proceeding steps tested OK & problem still exist, you may nee to replace The main control module.
Hope this will help you, if so please vote for it.
Mar 07, 2011 | Robinair Cool Tech 34700Z Recovery,...
When entering a game I hear sound but no picture. Plugged in correctly and TV set to HDM11.
If you are sure that you have your TV on the correct input, you can try resetting the PS3's video settings using the following procedure:
  1. Before changing cables, make sure the PlayStation 3 is turned off using the main power switch on the back of the PlayStation 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PlayStation 3 and television (or display) from the wall socket.
  3. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PlayStation 3 system.
  4. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  5. Plug the PlayStation 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PlayStation 3 back on (the line on the power button is now pressed).
  7. While the PlayStation 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PlayStation 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
If that does not resolve your issue, try the other steps here:
http://us.playstation.com/support/answer/index.htm?a_id=262
Oct 25, 2010 | Sony Playstation 3 (PS3) Console
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
I want to remove passenger side rear door panel because window is down and won't stay up
Hi!!
Here is a little information on how window regulator works. Also step by step instruccions on how to remove and install the window glass.
Door Glass & Regulator Power Windows
Diagnosis & Testing
When the rear window lockout feature is enabled, the circuit is open and no voltage is supplied to the rear window switches. When the feature is not enabled, the circuit is connected to battery positive voltage. If this circuit is shorted to ground when the lockout feature is not enabled, the PWR WDO circuit breaker may cycle continuously OFF/ON until, either the lockout switch is pressed to open the circuit, or the circuit breaker is permanently damaged. All windows may be partially or totally inoperative while the fault is present.
Inspect for aftermarket devices which could affect the operation of the system. Inspect the easily accessible or visible system components for obvious damage or conditions which could cause the symptom. Faulty electrical connections or wiring may be the cause of intermittent conditions.
Removal & Installation
Window Motor & Regulator
  1. Position window approximately half way down in the door.
  2. Remove the interior trim panel.
  3. Remove the water deflector.
  4. Tape the window to door frame to prevent it from moving.
  5. Remove the three front door window regulator motor screws.
  6. Disconnect the electrical connector from the window regulator motor.
  7. Remove front side door window regulator motor.
  8. To install, reverse removal procedure.
Window Switch
Front
  1. Remove the front door pull cup screws and pull cup from the front door trim panel.
  2. Disconnect the electrical connectors from the front door power window control switch.
  3. Remove the front door window control switch using a small, flat-bladed tool at the side of the switch.
  4. To install, reverse removal procedure.
Rear
  1. Remove the rear door pull cup from the rear door trim panel.
  2. Disconnect the electrical connectors from the power window control switch.
  3. Remove the rear door window control switch from the pull cup using a small, flat-bladed tool at the side of the power window control switch to release the power window control switch retainer.
  4. Remove the power window control switch from the rear door pull cup.
  5. To install, reverse removal procedure.
Sep 07, 2010 | 2002 Buick Century
Whirlpool dryer will not start the start buttton click when pressed and the timer works if i have the door open and press the start button there is no click so i figured it was not the door swich ...
The first thing to check on a electric dryer is the power.
I know It look like you have power but you have a 220V dryer and it need both sides of power to work.
If you can't ckeck for proper power at the outlet then please at least ckeck your breaker box and maker sure you turn both switches off and then back on to make sure that one site of the breaker did not trip. Then check your dryer to see if this did not solve your problem. ((((( I flip a breaker at least once a month for a customer and recive $60.00 for doing so :) ))))))
Ok if this did not solve your problem.
When you push the button for start do you here a hum noise ??? if so Most common problem would be the motor.
No hum.... Open dryer door and turn drum by hand and close door and retry dryer.
No Hum....
Now it get real fun !!! The start switch needs to be checked, Then the Thermal Fuse and the High limit thermostat.
In most cases this is going to be forign to you and you should call a tech for service.
Sep 05, 2010 | Dryers
Our Robinair a/c recovery machine has power to the switch, but will not power up at all, any ideas?
Please do the following : 1# Check main 15 amp circuit breaker (located on back of the machine) it may tripped, reset the circuit breaker. If breaker tripped again after reset, the circuit breaker need to be replace.
3# If all proceeding steps tested ok & problem still exist, you may nee to replace The main control module.
Jul 27, 2010 | Robinair Cool Tech 34700Z Recovery,...
While on vacation switched to 1080 now home and have regular tv now cant see to get back to regular. Im to the far right of menue. Need to know many to go right, down, button to hit to enter and then how...
Try resetting the video output. Follow the steps below:
  1. Before changing cables, make sure the PLAYSTATION 3 is turned off using the main power switch on the back of the PLAYSTATION 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PLAYSTATION 3 and television (or display) from the wall socket.
  3. Make sure the AVI cable is connected to the [AVI OUT] port on the back of the PLAYSTATION 3 system.
  4. Connect the other end of the AVI cable into the [AVI Input] port of the TV or display monitor.
  5. Plug the PLAYSTATION 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PLAYSTATION 3 back on (the line on the power button is now pressed).
  7. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Thank you for using fixya!
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
I have a timer light flashing and the set wii not turn on
you have a problem on the DM module, you need to replace 9 capacitors on the small power supply, the DM (digital module) module is the metal case on the left side of the chassi, you have to be careful whit it is very delicate
Dec 02, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Open Questions:
See all APC Smart-UPS 700INET (SU700INET) UPS System Questions
APC Smart-UPS 700INET (SU700INET) UPS System Logo
245 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Alun Cox
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
