I have an all in one but the scanner doe not work. I loade my hp flat bed and now everything in thst comes up on screen as lexmark and neither of them will scan. Help
my scanner does not work either. when you press the start button, nothing happensmy scanner does not work either. when you press the start button, nothing happens
You can't post conmments that contain an email address.
Its not drivers issue, hard ware issue.. Scanner assm faulty,replace it..For tech guys:Open flat bed glass, remove scanner assm clean inside reflector glass with ear buds & adf glass especially at home position.. lubricate on rail refix it back.. check it..
Step1: Open flat bed galss & optical scanner assm, clean flat bed glass, as well as clean internal reflecting glasses in optical scanner, ensure that don't use any kind of cleaners to clean the reflecting glasses, use ear buds to clean gently..Step 2: Replace optical scanner assembly..
1. Too much friction while moving the optical scanner unit.. Open the flat bed scanner lubricate the rail 2. Optical scanner unit faulty,remove the scanner unit open it gently, clean mirrors in side the unit with ear buds re-fix & clean the flat bed mirror neatly especially at home position.. re-fix as it is then check..I suggested this activity for only tec guys..
is this a flat bed scanner?? i'm guessing not. if its not you need to clean the thin strip of glass underneath the feed section of your scanner. use a clean soft cloth with some alcohol.
It will not scan by pressing the scan button, Can I get it to scan from the computer?
