Question about Olevia LT23HVX 23 in. LCD Television
Olevia LT23HVX screen resolution
I just bought a Olevia LT23HVX , and i have a problem with the screen resolution. when i connect my Laptop to the TV , with a resolution of 800 X 600 pixels on my computer , the TV works fine, but when i change the resolution on my computer to 1024 X 768 pixels, the TV gives me a "out of range" message. I read the manual and i know that the TV supports a 1024X 768 screen resolution , but how do I get this to work.?
Thank you guys
    Sergeant:
    Champion:
  • 298 Answers
It says 1024X 768 s in pc mode are you connecting
in tv mode or pc mode
Posted on Nov 29, 2007
  • 752 Answers
What kind of cable are you connecting with? If you are using a Composite or S-Video cable perhaps you may want to use the VGA cable instead and see if that corrects the issue.
SOURCE:
I'm looking for an owners manual for an Olevia 332-B11 it is approx. 10 years old. Any help?
Free User Manuals and Owners Guides ManualsOnline com
Try this site. It goes faster if you have the serial number and the make handy.
hope you find your manual,
kolbrun
Feb 01, 2015 | Olevia Televison & Video
My olevia LT23HVX does not power on
Try unplugging and replugging after waiting.
Jun 13, 2008 | Olevia LT23HVX 23 in. LCD Television
When i connect my computer to it it says out of range
Out of range simply means you have set the resolution too high thats all and you should lower it.
Apr 13, 2011 | Olevia LT23HVX 23 in. LCD Television
I have Olevia LT23HVX tv/pc monitor. Im trying to hook it up to my home pc but it keeps on saying OUT OF RANGE under pc. But for the tv is fine can youo help please.
"Out of range" meand the screen resolution of your PC doesn't equal the input possibilities of your screen
Check the resolution is compatible.
Feb 07, 2011 | Olevia LT23HVX 23 in. LCD Television
No sound. No picture. I just turned it on and the screen was black and there was no sound either. It has been working fine for the past 3 years. I have Dish network. They don't think it is their problem....
If you get the same results (no sound/picture) using a dvd player or other media device, then your power supply board needs servicing. If you have an extended warranty take it back...
Nov 10, 2009 | Olevia LT23HVX 23 in. LCD Television
Hooked to pc....starts up fine at
check your hd settings are correct on your pc.
Apr 28, 2009 | Olevia LT23HVX 23 in. LCD Television
I need a driver for my LT23HVX Olevia Display
Since this is a TV, you do not require a driver for it or any display device attached to a PC. The driver you need to update is the video card driver of your PC.  Once it is installed, it will be able to communicate with your TV or monitor's EDID (Extended Display Information Data) and be able to send an image to it properly.  The internal EDID will tell the video card what resolutions it can accept.
Mar 24, 2009 | Olevia LT23HVX 23 in. LCD Television
power supply board is the board where the ac cord plugs in .the . capacitors have numbers printed on board right beside them. there are three to change also check fuse on the board to.
Mar 12, 2008 | Olevia LT23HVX 23 in. LCD Television
Cable question
Make sure your refresh rate is set no more than 60HZ. Your monitor might not support refresh rates higher than that.Also try lower resolutions.
Here is a list of specs: (also try another cable)
Features/Specifications:
  • Olevia LT23HVX 23-inch HDTV Compatible Widescreen LCD TV
  • General Features:
  • Black cabinet
  • 23-inch active screen size
  • 16:9 widescreen aspect ratio
  • HDTV Compatible
  • 1366 x 768 native resolution
  • 1600:1 contrast ratio
  • 8 ms response time
  • 178° horizontal and vertical viewing angle
  • NTSC TV system support
  • 480i, 480p resolution support
  • Progressive scan
  • Color temperature adjustment
  • Built-in 5 watt x 2 speakers
  • PC resolution support up to 1024 x 768 @ 60Hz
  • English/French/Spanish language
  • Sleep Timer
  • V-Chip parental control
  • Energy Star compliant
  • Remote control included
  • Wall mountable
  • Front Panel Features:
  • IR sensor
  • Power
  • Menu
  • Channel down
  • Channel up
  • Volume +
  • Volume -
  • Source
  • Rear Panel Features:
  • 15-pin VGA
  • Audio in
  • Headphone
  • Component Y, Pb/Cb, Pr/Cr
  • Composite RCA video inputs
  • S-Video
  • Antenna
  • Power Specifications:
  • 100-240V, 50/60Hz, 2.5A (max)
  • 110 watts AC power consumption
  • Unit Dimensions:
  • 16.5 x 27.1 x 8.3-inches (H x W x D)
  • Gross Weight: 23 lbs
  • Net Weight: 21 lbs
  • Regulatory Approvals:
  • FCC
  • CSA
  • UL
Package Includes:
  • Quick Start Guide
  • Manual
  • Remote control w/two AA batteries
  • Power cord
Additional Information:
  • Notes
  • Model: LT23HVX
  • Product Requirements:
  • Satellite cable or antenna
  • PC with 15-pin VGA adapter
  • Stereo system with component, S-Video and composite jacks
  • Available power outlet
  • Disclosures:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 20-Inch to 23-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15mm (bright to bright dots)
  • Minimum distance between defects: 5mm (dark to dark dots)
  • Disclosures:
  • Consumer Notice:
  • This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009, to receive over-the-air broadcasts with an antenna because of the Nation’s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission’s digital television website at: www.dtv.gov.
Nov 29, 2007 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
366 people viewed this question
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
