U-Line 75R Refrigerator
Problem for U-Line 75R Refrigerator
Refrigerator compressor motor will not run.
By thomasfrank on Aug 11, 2009
Refrigerator is powered (light comes on when door opens), but the compressor motor does not start, no matter what setting on the thermostat. It is about 7-8 years old, and worked OK until recently.
Comments:
Aug 12, 2009
- Fan does not run, so I'll replace the thermostat myself. I've got the thermostat removed... where can I get an exact replacement part via the web? Any parts supplier links?
Aug 31, 2009
- I found an exact replacement thermostat at RepairClinic.com. The part number is 2766-S, their Item # 940414. Cost was $61.51 delivered. replacement is very easy... the trickiest part was finding the thermostat coil location, which is behind (and at the bottom) of the heat exchanger panel at the back inside the refrigerator compartment. Four screws and spacers hold the heat exchanger to the inside wall, and two bolts hold the coil to it. This fixed my problem and saved me many $$$$ for a service call or complete replacement of the refrigerator!
Oct 09, 2009
- Wow... if that thermostat from eBay is identical to the original part, that's half what I paid! Good find! Reassembly is just as easy as the disassembly... piece of cake!
Clarification Request
Posted by maddentim on Oct 09, 2009
thomasfrank, Thanks! your info helped me big time! I tested the thermostat with a multimeter for continuity and got nothing. You tips helped me get it out. I found the part on ebay for $30 delivered. Wish me luck getting it back together!
Best Solution
posted on Aug 12, 2009
Very Helpful)
admiralstopf
Rank: Guru
Rating: 91%, 88 votes
Does the fan work? If yes then the compressor has a relay and overload that might be bad. Or it could be a compressor that is bad. If its a compressor then you will need to have a tech verify that it is the problem. If nothing is running then it could be a thermostat thats not switching it on. Let me know if you need any more help with it.
Comments:
Aug 14, 2009
- If you visit the u-line website www.u-line.com and go under customer service you will see parts locator. There you will find who and the website should be there as well.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for U-Line 75R Refrigerator
Questions and Unsolved Problems for U-Line 75R Refrigerator
Do you recommend U-Line 75R Refrigerator?
Answer
Answer
I have a U-Line 75 Bev and need to replace the temperature control but cannot find the correct part... (More)
Answer
I had a flash of light and electrical smell from my bar area, I moved the fridge to ck outlet,... (More)
Answer
the norcold in my motor home works fine on propane, but not on ac or dc! could it be the heating... (More)
Answer
There is a small ledge container on the back wall of the fridge which extends across almost the full... (More)
Answer
gss22 ifre ge refrigerator,Have new part but it is a replacement to original wiring is not the same.... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in Windham, ME
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
