Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Jvc flat screen television model AV32F713 Black box on screen.
Large black rectangular box continues to pop up on the bottom portion of the screen. If I hit the volume button or change the channel the box will disappear for about 5 seconds then reappear. Box covers approx. 1/3 of picture and you cannot see through it. Even appears when a DVD is on. This is driving me crazy!
Ken
  • 4 more comments
  • ticked off 2 Nov 30, 2007
    I'm having the same problem and cc is already on "off", an the box will not go away. HELP!!!
  • divasmom Feb 04, 2008
    i also have a black screen opened on my screen too. Help me its so annoying!
  • JenBri Nov 11, 2008
    My black box is rectangular and covers 1/2 the screen. CC is off.
  • bethjody79 Dec 02, 2008
    same problem but i have sony 46" lcd ...black box takes up bottom of screen push any button on remote goes away but comes back.sometimes it does it sometime it doesnt. some times only on certian chanels.PLEASE HELP. thank you Jody
  • Anonymous Mar 18, 2014
    the cable box has been replaced but when you go to turn it on the blue screen appears and then it leaves
  • Anonymous Mar 21, 2014
    when I press the aquos net button I get a box telling me the server certificate has expired. I continue then a new box pops up asking for my username and password. I have never created a username or password. I have no idea what to do. the television is a 2011 model
On the reomte control (bottom) left of the sleep button is a cc button, push that until "OFF" appears on the screen. The close caption box should disappear. It worked for me, finally.
Posted on Dec 01, 2007
Ken i was reading online people were suggesting to turn cc off. I seen that i had my closed caption (CC) on. maybe it will help .i'll post if it does for me.
Posted on Dec 02, 2008
    Novelist:
    Champion:
  • 232 Answers
Go into your menu and turn off "cc" which is closed captioning,
Posted on Nov 30, 2007
I just solved the problem for the Sharp Aquos black box. The menu button on the remote only lets you set up the cc. The bottom of the remote has a little door, open that and there is a cc button. If you press cc, a little box will appear on the screen, one of the lines tells you the size of the box. Scroll to that line, keep hitting the cc button until it says off. I had to do it for a few stations individually, but the problem appears to be solved.
Posted on Dec 23, 2007
I hit the cap/text button on my tv remote, and the black box disappeared for good. Didn't hit any button on the digital remote.
Posted on Sep 14, 2009
Turning the CCD to Off seems to have helped. Thanks :-) Jenn
Posted on Oct 03, 2008
SOURCE:
Black box on screen
Look for bad stk's on convergence module. This may take care of pincushion too.
THanks
Mar 01, 2008 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
Black box on screen
Without a picture of it it's hard to say what you mean. Sometimes on a CRT TV the vertical scan doesn't fill the screen, but that would cause a black band both top and bottom. The usual cause is a capacitor drying out. But only a qualified tech should look into that.
Jan 04, 2014 | Philips Magnavox TS3260C 32" TV
Black rectangular box on screen from doing menu
Take ur tv remote go to menu check the captioning functions turn all CC1,2,3 off and all txt off too.Yes,text functions is on,that why u getting a big black block flashing on ur screen.
Mar 28, 2010 | JVC AV-32D305 32" TV
Black Box
You have inadvertently activated one of the closed-caption modes called T1 or Text 1. Find out how to turn the closed-captioning off and on and you'll be able to turn this off.
Mar 30, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Black box in middle of screen
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Dec 01, 2008 | Toshiba MV13L2 13 in. TV/VCR Combo
Unwanted rectangular black area appears on screen blocking 40% of picture
This could be the result of a partly shorted vertical winding on the deflection yoak.Since the line is on an angle and not straight across.
Nov 07, 2008 | Durabrand DWT1304 13" TV
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
1,020 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
