Question about Maxtor Hard Drive
Jumper setting for hard drive
Hi there, I have a Maxtor 20.4 GB hard drive that I wish to use as a primary master in a PC that I built.I cannot seem to remember the jumper setting for this such drive.It will be the only hard drive in the system(without a slave drive).It just has no diagram(which I am used to seeing)....grrrrr. Can you help me out please?
  • Anonymous Jan 04, 2009
    NEED TO SET MAXTOR HARDDRIVE TO MASTER
  • SOCOOL_16 Jan 04, 2009
    I NEED TO SET A MAXTOR HARD DRIVE TO MASTER
  • 25 Answers
If you know the model number of the drive, you should be able google it and get info on the drive jumpers.
Posted on Nov 30, 2007
How the jumper setting is done for maxtor n256j50
If this is an IDE/PATA hard drive then the jumper settings are marked on the circuit board.
MA = master
SL = slave
CS = cable select
If this hard drive is the one installed on the Primary IDE controller the the jumper has to be set to Master. If it won't boot up then the jumper needs to be set to Cable select.
If this hard drive is a second hard drive and is connected to the 2nd connector on the IDE data cable that is connected to the primary IDE controller then the jumper must be set to Slave.
If this hard drive is a second hard drive and is connected to the secondary IDE controller and there is no other drive on the IDE data cable other than this hard disk the the jumper can be set to either Master or Slave.
If there is a CD drive on this cable too then the drives on this data cable then the jumpers on each drive must be set differently, they cannot be set the same jumper setting.
Feb 09, 2011 | Maxtor Hard Drive
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
What is the jumper setting for 'Slave' on Maxtor
Look at the picture, I cannot memorize all hardisk jumper but almost all drives have label in it. where you put the jumper for the Cable Select, Master, Slave.
See picture below. Opposite pins has label on it to where you put the jumper.
Oct 24, 2009 | Maxtor DiamondMax 6L160P0 160 GB Hard...
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
Chris
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
DiamondMax 21 80-GB ATA/100 Hard Drive didn't get recognized as 1st drive or 2,3. do i need any software.
Use a partition manager to see if the drive is recognized. If it is not recognized, you may not have the jumper setting correct. If it is a master drive, set the jumper for master drive. same for slave or cable select
May 05, 2009 | Maxtor Fireball 541DX (2B020H1) 20 GB Hard...
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Jumper settings
how many pins in that hard drve?..let me analyze to you this, if the hard is in front of you, you'll see the connection of the ide cable and power cable, then the jumper setting pins is in your left,am i right?..so the pins is figure like this, : : : ., is that right?..the first pin(from top to bottom)is the master, and second one, is the slave and the last is cable select..
Feb 26, 2008 | Maxtor DiamondMax Plus 6800 (92049U6) 20.4...
Maxtor 52049U4 20GB hard drive jumper settings
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
Nov 12, 2007 | Maxtor DiamondMax Plus D740X (6L020J1) 20...
Maxtor Hard Drive Logo
108 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
