Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
Rca scenium 52 inch replacement screen
I have a QVC image burned into the screen. Can I replace the screen? How much?
Try hooking up a computer and turning on a screen saver that will display an all white screen....leave this image on your screen for an hour and then go back to a normal pic....i have seen this work on Lcd's....should work on crt projection
Posted on Dec 19, 2007
    Novelist:
    Champion:
  • 232 Answers
I`ll have to be the bearer of bad news, the image is not burned onto the screen it is burned into all 3 of your picture tubes, which basically means the set is junk because the cost is too high.
Posted on Nov 30, 2007
How can i fix my double image in my 52' inch RCA
A few questions and some info---if the convergence issue is missing in the menu you have a part near the high voltage transformer bad.
Many of the 52 inch sets made from 2004 and up have bad connections around the high voltage transformer which will create that and other issues.
If not in the menu there is a kit sold on the internet with the protect part that fails and a cap and diode that should be replaced at the same time.
Let me know as much as you can--note that all the parts are soldered in so you need to be able to test and solder as well.
May 20, 2012 | RCA Televison & Video
RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
Rca scenium 52" has light bar area down each side
I take it that you have watched many hours of 4x3 video on this 16x9 TV . What you see is evidence of screen burn, like they used to warn about with the old "pong" type games with stationary objects. The 4x3 pattern is burned into the phosphor in the projection tubes. the area of the burned pattern is not as efficient as the unused areas that make up the 16x9. If you watch enough 16x9 it may even out somewhat, but will never be perfect. Replacing the tubes will fix it, but they're pricey, and you may be subject to it happening again, depending on your viewing habits.
May 25, 2009 | RCA Scenium M50WH187 50" HDTV
Picture freezes and turns its self off and then turns back on
this happened to me with my RCA Sceium 52 inch floor model, for 2 years before I figured out it was
over heating. Of course I had no money to fix problem. What I did is simply put a cool fan on back
or AC. Even rolling in front of a sliding glass door when its cool out will work well. Cold air on back
will stop it from turning off.
Good luck
Apr 26, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
52 inch rca scenium wont turn on
this is an indication of a shorted horizontal ouptut transitor and bad flyback transformer
Mar 14, 2009 | RCA HD52W58 52" TV
How do you change a RCA bulb on a Flat Screen Televison
GO ONTO ASK.COM AND ASK THEM OR GO ONLINE TO THE ADDRESS BAR AND TYPE:
RCA SCENIUM HD50LPW52 SERVICE MANUAL
OR
HOW REPLACE A BULB FOR RCA SCIENIUM HD50LPW52
ENTER
ROD
Feb 17, 2009 | RCA Scenium HD50LPW52 Replacement Lamp
RCA Scenium
What does the picture look like when it is on?
Dec 03, 2008 | RCA Scenium D40W20 40" Rear Projection...
Have sound no pic. on 52 inch.
if you have some thin lines on the top of the picture probably you have a problem on the power supply for the convergence
Sep 29, 2008 | RCA Scenium D40W20 40" Rear Projection...
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
323 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
