I recently purchased a new laptop which has Vista installed. I have an HP iPAQ 4150 that I had not used for a while because I was using company computer (at home) with Blackberry. The manual has been misplaced so I have no reference for installing the PPC to my new laptop, which means I need HELP. I haven't the foggiest idea on how to start. I did try some research and have heard of folks who are able to use this model with their VISTA OS. I have gone to Microsoft and downloaded the latest version of the WMDC. However, I am still unable to sync. My PPC Com Ports show up as 8 and 6 and I cannot find a way to change them. VISTA bluetooth is set to 5 and 4. Don't know if I need to find a way to change them. Or if I even should. Do I set up a partnership? If, so How? My laptop is connected to a wireless network so should I be setting up a Proxy? VPN? (Don't know enough about them to to know if I do that). Can someone please give me some information and hopefully easy to follow step by step directions. I am getting so frustrated!!!!!!
I have same problem as the original poster - it's not activesync that is not compatable, it's the fact that the HP 4150 runs windows ce v4.20 and THAT isn't compatible with the Vista sync. It doesn't work and the MS documentation says it's not compatible.
I need to resolve this exact issue too so other suggestions and/or solutions are VERY welcomed. -   launcher
the Active Sync program on the HP's is not compatible with Vista. I solved this problem with my 3715 by downloading a program called Easy Sync from Handango. It works like a charm, every time. Good luck
The Microsoft Windows Mobile Device Center requires that the first sync be made via the USB sync cable. After the h4150 is plugged into the Vista machine, the WMDC opens and prompts you through setting up a partnership. Then you can set the h4150 to sync via Bluetooth.
ActiveSync works fine with Vista. Ignore that other guys post.
Hey I have an Ipaq H4150 and Orange Livebox, I can see the Wifi conntection but the pda wont...
(More)
Hey I have an Ipaq H4150 and Orange Livebox, I can see the Wifi conntection but the pda wont connect, it says connecting then reverts back to available. I have updated rom and done various other firmware updates, any ideas?
I have a Ipaq 4155. It will say it is charging when it is plugged in but as soon as I unplug it the...
(More)
I have a Ipaq 4155. It will say it is charging when it is plugged in but as soon as I unplug it the screen goes blank and it will not turn on. When it is plugged in I see that the backup battery is 0%. Will this keep it from charging. The rechargable battery is new. Any ideas??
I get a green Icon on my WiFi showing that I'm connected, but when I try to type in a web address I...
(More)
I get a green Icon on my WiFi showing that I'm connected, but when I try to type in a web address I get an error that the address is not valid and that I should check the address and try again. How can I fix this or do I need a expert to fix this problem i got same problem when i tipe a web page there is error that seid the web page cannot be found is that something bad?
I have an HP Ipaq 3715, I bought a new laptop that is running Vista Home Premium. I have downloaded...
(More)
I have an HP Ipaq 3715, I bought a new laptop that is running Vista Home Premium. I have downloaded the WMMD 6.1 and my laptop and device connect, however, when I try to sync I get an error message w/ no info on the error, My change content settings is greyed out,so I can't try any changes there, I think my problem is that my device is attempting to sync with an exchange server and not my pc, but I don't have the foggiest how to change the settings, can you help???
Chuck
