Question about Sanyo MM-5600
SANYO MM-5600 Hi my phone will not take charge could my battery have just went bad completely that quick?Thanks Doug
    Guru:
  • 1,049 Answers
If you use a car charger, use a wall plug instead and replace the battery; because a lot of car chargers can harm battery life…especially if that is all you’ve ever used. Also check the settings on the phone, if you have disabled power saving features that dim the screen after so many seconds then the back light will drain the battery very quickly. Use name brand batteries and not the ones that come with the phone, Sometimes the ones that come with the phone can ****. Finally, make sure that you do not have a short in your wall charger and that the first time you use a new battery you charge it fully to begin with and don’t charge it again until it is completely depleted. Supposedly newer batteries do not have to be primed, but I find it is a good practice anyway. Use the charger that came with your phone, the voltage/amps are not always just right if using a radio shack special.
Posted on Oct 02, 2009
My wife and I have the same model of phone Sanyo 3810. When we close our phone, it intermittently goes blank for about 30 seconds and then is searching for service. There is a message in Red that say...
spray the battery compartment down with silicon spray (Napa auto parts) then quickly wipe,,,,,spray(drench) the battery charging inlet,,,then tooth brush it,,,,attach the battery to phone,,,but this time place a papertowel spacer between battery and battery door,,,,secure cover,,,then attach charger cord to silicon drenched inlet,,,,,wait till charging is completed,,,,,then you are finished!!!
Dec 10, 2010 | Sanyo SCP-2700 Cell Phone
My battery to my phone wont charge for some reason the chargers arent broken but it just wont charge help!!!!!
Hi the chances are the battery in the phone has bad cells this causes the battery to seem charged when its actually flat, the only option you have is to replace the battery and that will solve your problem.
when you get a new battery do the following.
every say 6 weeks let the battery go totally flat so that it wont even turn the phone on then do a full charge over night, doing this every six weeks keeps the battery at its best and prevents it from getting any bad cells so doing this will improve the life of the battery.
turning off bluetooth saves the battery as well if this is switched on all the time then this will drain the battery really quick its best you only turn it on as and when needed.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 18, 2010 | Sanyo SCP-2700 Cell Phone
Phone dies when i make a call very quickly
hi bill,the problem is from your phone battery,the phone battery is bad and it needs a replacement.when you purchase the new battery,ensure you charge for at least 5hrs before initial use.
take care
Mar 02, 2010 | Sanyo SCP-3100 Cellular Phone
Sanyo 7400
The charging circuit has failed; time for a new phone.
I love my BBW MM-7400, had mine for years…
Great phone; never a problem with her.
Mar 26, 2008 | Sanyo MM-7400
Sanyo 5600 - Camcorder
Is it on vibrate? Even if sound is up, if your phone setting is on vibrate you will not get playback sound.
Dec 24, 2007 | Sanyo MM-5600
Sim card slot
No, sanyo 5600 doesn't
Dec 06, 2007 | Sanyo MM-5600
Copyng mp3 in Sanyo 5600 phone
Your mp3s don't go to the built in media player, they are stored on your mini sd. If you go to Tools/Extras and scroll down to 7 miniSD, then miniSD folders, then Media, it will bring up your mp3s. Or the easy way, from normal screen press the left button in the centre (with 2 boxes, 1 with a tick in it) and that is your shortcut button with media in miniSD at the top. Hope that helps
Jan 13, 2007 | Sanyo MM-5600
Audiovox SMT 5600 will not charge
If your battery goes COMPLETELY dead, which it will do if phone is not turned OFF and not used for a long period of time, you will need to JUMP START it using you OEM SMT-5600 AC charger. Other AC chargers will not work for this purpose and neither will a USB port.
You can JUMP START the battery using a USB port by cutting off a USB cable to expost the red and black power USB PORT power pins 1 and 4. Remove your SMT-5600 battery and while the modified USB cable is plugged into your USB PORT, hold the BLACK wire to the negative (-) terminal and the RED wire to the positive (+) terminal for about a minute. Replace the battery in the phone and connect the phone to a USB PORT using a standard USB cable. The SMT-5600 charging light may not register for a while, but will eventually light amber to show it is charging, assuming your phone is recoginzed by your computer.
Note some mini USB cables DONOT carry the USB power leads through to the phone, only data. If you have a very thin USB cable, be suspicious the power leads are not being carried in the cable.
Since the USB PORT power is limited to 100ma it cannot hurt the battery, but will insert enough current into a totally flat batter to cause the battery to register a voltage large enough to alllow USB PORT charging, typically 3.7VDC.
Nov 18, 2006 | Audiovox SMT5600
Sanyo MM-5600 Logo
74 people viewed this question
Top Sanyo Cell Phones Experts
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
