Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
PT-53TW5353 There are neon colors such as green purple and pink aslo the writing shows double like all the settings and anything else that is on the screen
  • 934 Answers
Nikki,
The convergence amps have most likely failed. Your set takes two STK392-110 Sanyo built Ics, Pansonic p/n# C5aa00000203.
They're located at board positions Ic7001 and Ic7002 respectively. In addition, you will need to test all the low ohm yoke return resistors in that circuit for change in value and replace any that don't meter correctly.
In the shop this is a relitively modest job with the most of the cost going to labor. I suggest, if you're going to have a shop do it call around and ask what they charge for changing the convergence amps and take the unit to them to save the pickup and delivery charges.
Good Luck!
Bill
Posted on Nov 29, 2007
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
Purple and Green haze on television image
Do you have any speakers near the TV, that aren't shielded... ?That's kinda what it sounds like to me.
Apr 10, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Pink and green with double writing
this is a internal problem you should call 1-888-PHILIPS (744-5477) to set up service. It is usally a main board problem
Jan 08, 2009 | Philips 52PFL7432D Television
Are you able to do a multipoint convergence adjustment in the convergence menu? Do the red and blue adjustments move in all four directions/ Let me know and I will try to assist you.If the anser is no to either problem you will need new convergence ICs and convergence resistors.
Jan 08, 2009 | Philips 60P8341 60" Rear Projection...
Neon Pink Lines
"eprom upgrade" by Panasonic tech will solve the problem.
Jan 13, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Green....purple....colors
If you are technically savvy and you can solder.....requires
chassis pull...replacement of convergence IC's...mounted on large heatsinks on board to the right looking in from rear....If
you want help........Let me know................T.
Dec 27, 2007 | Panasonic PT-53WX53 53" Rear Projection...
My toshiba tn61x81 projection tv
have you tried the convergence option in the menu? i believe it is under "picture". this allows for nine different sections of the screen to be adjusted when projection images get out of whack.
Oct 20, 2007 | Toshiba TN61X81 61" Rear Projection...
Panasonic Model No. PT-47WX42F
Replace the convergence amps. That unit takes two Sanyo STK392-110 and you could use 150's for greater reliability. Also replace one or more of the 1.2 ohm resistors in the yoke return circuit out front of the amps.
Oct 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
