Question about Dell Latitude D800 Notebook
Laptop won't boot up
When I turn on the laptop, all the lock lights come on and then it shuts off. Every once in a while I can boot it up to the choose user screen but the key board or mouse won't work. Please Help Dave
  • 383 Answers
Key board make sure it is hooked up right.
Mouse make sure it is hooked up right as will.
Num lock is- the only light that should be on at all times.
Click on : Scroll Lock make sure light (is off)
Caps Light - is for Capital letters
Hope this helps ya .
Posted on Nov 29, 2007
  • sheila skaggs Dec 20, 2007
    Getting into Windows Safe Mode
    Users who may not be able to boot into normal mode or are not able to ... press and hold a key as the computer is booting you will get a stuck key message.
    Good Luck, Please dont for get to Vote.Thank You.
SOURCE:
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Toshiba P745-s4102 won't boot or restore to factory settings
I have Toshiba P745- S4102 . When I open a window it freezes. I have to do a hard shut down each time I turn on my laptop.
I want recover my laptop to it's factory setting. I brought the laptop from bestbuy brand new. It did not come with a CD for recovery. I have windows 7
Apr 18, 2013 | Computers & Internet
Dell inspiron 1300 won't boot
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Sep 21, 2012 | Dell Computers & Internet
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Laptop intermittent startup problems
if you need your laptop always in ready use change the time your computer is on in control panel then log off your device will be on always until you shut it down it constantly drains battery
There is a way to fix this try reinstalling windows
or just take it to software mechanic
Mar 21, 2017 | HP Compaq Presario v4000 Notebook
looks like a harddisk, memory or bios or battery problem
isolate each possibility by
using it without the battery
borrow a memory and swap it and try it
swap the harddisk if it is easy to remove and not password protected
and then get back to me
Dec 02, 2007 | HP Pavilion dv1000 Notebook
Dell Latitude D800 Notebook Logo
169 people viewed this question
Ekse
Clive
Clive
