Question about GE WSXH208A Front Load Washer
GE front loading washer softener dispenser does not dispense
Model #GCVH6260 (Canada) dispenser fills with water but does not dispense the softener and remains in the dispenser
  • 3 more comments
  • Anonymous Feb 25, 2008
    I'm having the same problem - I've cleaned the tray but it still does not dispense the softener
  • Anonymous Mar 04, 2008
    The bleach and fabric softner does not empty out by the end of the laundry cycle. I have taken out the drawer and cleaned it out, but the problem continues. The dispenser does not dispense the bleach or fabric softner. Any suggestions on how to fix this problem.
  • Anita
    Anita Oct 11, 2008
    I can not change the water pressure, it comes into the house from the city lines. I will try the vinegar. If that doesn't work, do you think I can try CLR?
  • vtandi Dec 09, 2008
    I have tried everything to "clean" this dispenser so that it will dispense bleach and softner and nothing works, including running the prewash cycle as described in the manual. If I leave the compartments empty and run a wash, they are no longer full of water at the end, so it would appear that the unit is not clogged. The mention of water pressure here is the first I have seen. Are you saying it may be that while water can run through the system, the pressure is insufficient to "push" the bleach and softner ahead of it? Why then would it work "occassionally" (very). I do not have the ability to adjust the water pressure on just my washer. Does anyone have any other suggestions? Does "topping" the product with water produce the same effect?
    Please help!!!!
  • Anonymous May 07, 2009
    Indesit Washing Machine W161 softner dispenser does not work.
I know this was posted nearly a year ago...
But, we had the same problem with our washer-- the dispenser wouldn't work on the softner and bleach. After googling all the threads I could find, I decided to run the "quick wash" cycle with vinegar a few times (just like you would do when cleaning a coffee machine).
Everything looked so clean inside the dispenser and it still seemed to have the problem. So, I began to think that perhaps it wasn't filling the holding area enough with water-- which in turn would not allow the softner and bleach to be added to the clothes. I double-checked the water lines and found that we had turned the water presure down because of water hammer. I turned up the pressure, and now everything works fine-- except now we have to deal with the water hammer!
We hope this discovery helps some others out there...
Posted on Oct 11, 2008
  • 1,294 Answers
After you put your normal softener into the dispenser, top it with water. The remaining water the machine will pour in. You can even try cleaning it with a toothbrush first.
Posted on Dec 04, 2007
  • prem mathew Mar 05, 2009
    You can turn up the water pressure before you do your washing, & turn it down after. Time it to remind you. Its what i do always. And I've had no probs at all. If all this persists check your inlet valve (at entry top of machine) for loose connections, still not good change the inlet valve, it's easy.
    Sites for spares: (which is good)
  • prem mathew Mar 15, 2009
    If the softener does not emply from the dispenser you have to open the top to see if line is coming through to it & is not disconnected or loose. Check your inlet mesh at machine too (where the water comes from the wall faucet to the machine entry).
How do I get the fabric softener dispenser to keep from filling with water?
Remove dispenser and clean the drain hole from under neath try with q tip.sounds gunked up.
Sep 01, 2014 | Frigidaire Affinity ATF6000F Front Load...
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
The softener and bleach compartments are always filled with water. Also, the dispenser drawer is VERY dirty. How do I remove the drawer to clean it?
I have the exact same problem. Ive taken the hoses beneath the drum apart in case it is backed up all the way to the dispenser. Found a bra wire and removed it. Ran another cycle - still the same problem with water in the dispenser - even running down the outside front face of the washer. Not sure what to do next?!?!?!
Nov 06, 2010 | GE WSXH208A Front Load Washer
Our Kenmore HE 2Plus Front Load washer model # 110.475*4753 is haveing an F03 Error and we can not get it cleared. Any ideas? We have hit stop twice, and cleaned the hoses, nothing clogging
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 13, 2010 | Kenmore Elite 45986 Front Load Washer
GE WSXH208AWW doesn't dispense detergent, softner or bleach. Dispenser is totally dry after wash cycle.Appears no water gets to tray.
I'm having almost the same problem - the bleach & softener both will NOT dispense, but (LUCKILY) the detergent does dispense on mine, for now.
In order to get the solutions (bleach, softener, detergent) to go into the washer, the water needs to pour through the dispenser somehow. Dry means NOT working (mothmanmeg).
I need help, too!! We tried taking the drawer out & cleaning, no luck.
Apr 17, 2010 | GE WSXH208A Front Load Washer
GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
Jan 28, 2010 | GE Energy Star WCVH6260F Front Load Washer
My Ge Adora washer fabric softner dispenser
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Dec 09, 2009 | GE WSXH208A Front Load Washer
The water softener dispenser fills with water each wash...
This is pretty typical....other than dumping the drawer out each time, I have not seen a solution for this complaint. If it is having trouble dispensing softener, you could try raising the front legs 1/4", this helps create a better siphon in the dispenser.
Apr 21, 2009 | Kenmore HE2 Plus Front Load Washer
GE WSXH208A Front Load Washer Logo
1,650 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
