Question about Flat Panel Televisions
How can i get subtitle on TV program via digital cable box from rogers?
I can get subtile for the TV program if my TV connect to the cable(Rogers) derectly, but if my TV connect the cable via roger's digital cable box, how can get on subtitle?
  • 58 Answers
SOURCE: Dead set
change the 330uf or 470uf caps in the power supply.
Sometimes they will show a slight bulge on the top sometimes not
Posted on Jun 12, 2008
SOURCE: I can't seem to get the proper colour back
I unplugged everything from the wall outlet and Roger's box. When I plugged it back in the colour was much better.
Posted on Nov 15, 2009
  • 1140 Answers
SOURCE: how would i program my
Please rate this solution if you find it helpful:
It would help to specify the model of remote control or TV, however, here is the guide to programming your Rogers remote for any television:
Posted on Oct 14, 2010
SOURCE: my rogers hd box the
Have you tried a signal booster, i really do think that will help. Your reception can be to do with a few thing's, i.e. Position of your tv, Faulty receiver on your main (outside) aerial, A breakage or fault with the aerial cable coming from outside aerial to tv, or your outside aerial can just simply have a bad signal.
SOURCE: LG 42PC5D and Rogers Cable
Posted on Nov 04, 2010
  • 19396 Answers
SOURCE: i'm hearing two programs on
Since cable channels are digital, the problem is not caused by interference. With digital channel interference causes noise (no audio or white noise), rather than reproducing analog signals from different channels. The problem is the Rogers box. The Rogers box has features that allow you to listen and watch more channels at the same time. In normal condition this can only be done activating PIP features.
Your Rogers box is instead broadcasting double audio on channel probably because faulty.
If the second audio is very faint, there is also the possibility of an analog radio signal interference being caught by one of the audio wires. In that case the sound will not be a TV channel audio, but a radio channel from local transmission.
If you get audio from two different TV (or digital radio) channels at the same time, then you probably have a defective Rogers box.
Try disconnecting box power cord for five minutes. Also test using different connection to TV if possible.
If that does not work, call the number listed in Rogers documentation. The operator will ask to perform a simple test on the box, and then willl eventually send you a new box.
See also TVRogers
Posted on Nov 06, 2010
0 characters
1 Points
When I turn my converter box on it boots then shows 4 green lines. How can I fix it?
Lorie, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Easy Fixes to 5 of the Most Common Rogers TV Issues
3 ways to troubleshoot your Rogers Digital TV Rogers RedboardRogers...
Mar 07, 2016 | Flat Panel Televisions
I have a fluid TV that is hooked up to my Rogers cable box but I cannot get a signal. I tried all the input, I don't have the remote control. How can I fix this problem?
you need to program the channels without using the remote control, as it can only make you download the user guide for your TV by model
Jul 02, 2015 | Flat Panel Televisions
I swiched my sharp from a working Bell PPV satellite signal to a working standardCable Coaxial connetion from Rogers, while my two samsung tvs are working onthe rogers coaxial signal, the Sharp is not...
Good day!!
OK please try to go to the menu using button on your TV...after that find the auto scan mode...
please complete the 100% scan for better results...
if the problem persist try to play DVD or any recorded TV show to determine if the problem is on the signal or on the TV itself (the tuner is weak)..
Jul 10, 2011 | Flat Panel Televisions
I have recently gotten a Sharp AQUOS Quattron (LC52LE810UN). I have a rogers cable box with a RCA input, but the tv doesnt not have an direct RCA input. It has a input for an audio cable with a component...
Your TV is a High-Def TV (HDTV) therefore you need a Rogers cable box and service capable of High-Definition in order to get the HD resolution you paid for with the HDTV. HD video requires HDMI or component video cable connections. Standard RCA AV (yellow, white, red) will not show HD video.
Having said that, you may want to hookup a game or VCR to the TV and therefore you will need to get a cable known as an AV miniplug. It has RCA (3) on one end for the VCR for example and on the other end is a Mini-plug to connect to the HDTV (Sharp). This cable is like the ones used on camcorders such as Sony. Make sure you get a cable with the right ends as depicted in your manual on page 14.
You'll have to Google online for a supplier. had these cables but are out of stock currently.
Jan 17, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Certain channels on the tv flicker when I change channels and the screen will black out for about 3 seconds as if it's seraching for the signal. The flickering and blacking out is very intermittent. I have...
Rogers cable is using what they call "switch digital" this allows more channels to be placed on the platform they are using to give you more stations. This basically means people on the same line that you are, are not watching this station so they put that station "off" until someone tunes into it.
Nov 20, 2010 | Flat Panel Televisions
How would i program my rogers remote to my lg tv to be able to change the volume without having to use the two remotes
Oct 14, 2010 | LG 42LC2D 42 in. LCD HDTV
I have succesfully connected my dynex 32" lcd hdtv 720p 60hz to my rogers digital box and my xbox but i only have room to connect my audio cables for my surround sound speakers to my tv cables there is no...
What cables are you using for the XBOX and the digital box? What surround sound system are you using (what receiver)? Which model of Dynex 32" TV do you have? Looking at the DX-L32-10A, I can connect both devices to the TV and then the audio out to the surround sound system.
If HDMI, then that will carry the audio to the TV and then you would need an audio cable from the audio out on the TV to the surround sound speakers. Similarly, if you use component video and the audio cable combination, there are 2 component video jacks and 3 audio-in jacks on the rear of the TV. Then connect another cable from the audio out of the TV to the surround sound system. (This TV has one audio out and a headphone jack.)
If you previously had the audio going from the Rogers digital box directly to the surround sound system, you need to reroute things unless there are two or more sets of audio in jacks on the surround sound system. Some surround sound system can take several HDMI in cables and then route it to the TV on a HDMI out port.
Without more information, I can't be sure of the best option for your cables.
I hope this gets you started and please provide more information for additional suggestions.
CIndy Wells
Sep 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
40 inches toshiba (40RV525U) no CC with dvd movies
That I don't think you can do - the CC is fed by the digital tuner, while the subtitles are fed by the DVD player.
Oct 17, 2009 | Toshiba 40RV525U 40 in. LCD TV
Turn off tv power
First your tv will always go into "Standby" when it receives a "Power off" signal. Made that way. Second, It is never a good thing to have your tv power plugged into a "Switched" outlet on a Cable ot Sat box or some other Component. The tv should be always be plugged into the wall outlet or through a very good surge protector.
Jul 12, 2009 | Flat Panel Televisions
Flat Panel Televisions Logo
1,091 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
