Question about Mitsubishi WS-73713 73" Rear Projection Television
Powers ON then OFF after only 6 seconds?
First, Thanks for helping me fix the initial Problem: I had the "Eternal Blinking Green Light". I took the box up to my TV Repair Store & had him replace the 4 "Popped like a Coke can" 15V 1000ui caps with 4 new 1000ui 35V caps. Then I brought it home & installed it.
Green light STOPPED blinking......Thanks a million! Now...when I Power ON the TV it comes ON for about 5-6 seconds clicks & Powers OFF on it's own. What the heck is going on? I have tired head.....I thought I had it fixed!
Please share with me what you think it might be or is. I reset the TV & pushed the MENU button for over 10 seconds....and still the same problem.
Silver Lining: At least we fixed the "Eternal Blinking Green Light".
Thanks in advance for your assistance & recommendation(s)....
Steve :)
  • 2 more comments
  • Red Rocker55 Nov 30, 2007
    Hello again Bill,
    Thanks again for your help & assistance! I did as you recommended by removing the E2P module. Must not be it.....the TV Powered on for about 5 seconds, then clicked & Powered OFF again....No picture at all. I'm in the freakin' weeds on this?
    I then put it all back together & did the Self Diagnosis feature & it blinked 2-1 = X-ray protect (high voltage or beam current). What pray tell does this mean?
    What do you recommend my next step or steps to be?
    Thanks a million again for your help,
    Steve :)
    Thanks Bill for all of your help & assistance! I really appreicated it! I'm way in over my I'm going to call my Electronics store to come out to repair it.
    Merry Christmas to you & your family,
    Steve :)
  • chumley47 Feb 06, 2009
    my tv turns on for 6 seconds and then clicks off with no picture
  • Anonymous Mar 14, 2014
    I have 2 green blinks, then 4 green blinks
  • 934 Answers
The caps you're describing are in the power supply of the DM and a very common problem. Another problem in that same box is the E2P module. The E2P is a small board towards the rear of the module plugged into the module with a multi-pin connector. Unplug the E2p and re-install the DM and see if the unit powers up... If it does the picture won't look very good but at least you'll know if the E2P is keeping it down.. If it still won't power you've eliminated the E2P as a porblem.
Next let's take a look at the error code for some clues. This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Then, let me know what you find...
Posted on Nov 29, 2007
  • William Rayburn
    William Rayburn Nov 30, 2007
    The only nest step is to troubleshoot the power/signal module. That's the large board that the DM plugs into... Most of this will require at a minimum a 20m scope to trace test signal and logic.
    What's happening now could and most likely is in your low voltages - 5, 9, or 12 I'd suspect and all of those are located on that board together with the main stage regulator...
    If you don't have a scope your only next option would be to unbutton that board and send it into PTS Electronics for bench testing and repair. Their web site is: and their contact number is: 800-844-7871...
    I believe their bench testing fee is $50.00 dollars and that's incorporated in the cost if a repair is required... These guys are good and quite reputable. Techs like myself to handle overload in the shop..
    Make sure to pack the board well. A little foam rubber top and bottom will work nicely and fill-in the gaps with foam peanuts.
    Their turn-around is about two weeks - maybe longer with the holidays upon us.
    Good Luck and let me know...
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
3 Reset System
From the remote, press
<MENU> <1-2-3>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
All customer settings are
reset to factory default.
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
62hmx95, blinking light, powers on then off
Examine in order the lamp, the ballast, the fans.
Apr 29, 2012 | Toshiba 62HMX95 62" HDTV
The PS3 system powers on for a few seconds, will go through the normal process and get to the main screen. After roughly 10 seconds it beeps three times and powers off, with the red light on the front...
i had the same problem and it was fixed hwen i took apart the playstation and cleaned it there was some dust inside and i guess that fixed the problem for me good luck!
May 25, 2011 | Sony Playstation 3 (PS3) Console
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Blinking Green Light of Death
I had this similar problem TWICE!!!. I called around for a repairman and they charged over $300 dollars to repair (HELL NO). Anyways I took a trip to Vegas hoping to win some of the money to repair it and left the TV plugged in and BLINKING during my trip. When I came back it was not blinking anymore and I got curious. Well I pressed the power button and to my surprise IT TURNED ON!!!!. A month later I moved to a different house and unplugged my TV to move it and when I plugged it in the DAMN BLINKING GREEN LIGHT OF DEATH was back. Well I thought I'd get lucky again and leave the blinking on, well 2 days later the blinking was gone and ONCE AGAIN MY TV WAS ON...... I hope this helps and works for other people. My point is, before you pay for a technician to repair it and before you give up on your TV and unplug it, Try leaving it on BLINKING for a few days and see what happens.
Oct 07, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Toshiba 62hm14 TV turns on with no picture but has sound then green light blinks and it shuts off
This isn't gonna help you, but I have the same problem on my 62HM15A, think we have about the same tv, widescreen DLP,?
My TV does the same thing powers with a blining lite then powers off. First it powered on with sound no pic, then would shut down and power up again with pic and sound , now i gots a nothing just powering on and off until i shut the thing off manually.
thanks, just posted here in case some answers bipea's question and it relates to mine.
Jul 23, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Mitsubishi WS-73713 73" Rear Projection Television Logo
185 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
