After going through the carb. adjustment procedure: Every thing seems to be fine until I put it to the wood. The it soon looses power, the chain stops & the engine is still running (at a reduced RPM). What is the problem?
HI. FRIST OFF THOSE SAWS ONLY WORK GOOD AT HIGH RPM.NOW I ALWAYS SET MY HIGH SPEED AT 3/4 TURN AND THE SAME FOR THE LOW. WHEN YOU START IT UP, FIND A PICE OF WOOD THAT IS A BIG PICE OF WOOD THAN YOU SHOULD BE ABLE TO SET IT UP. IF THAT DOSEN'T WORK GET BACK TO ME THERE ARE OTHER THINGS YOU CAN CHECK. THANKS JIMBO
