Question about Whirlpool LEQ9858P Electric Dryer
Can't remove motor from dryer
My first dilemna was that the blower wheel on my Whirlpool electric dryer was completely stuck on motor shaft. I was just trying to remove the wheel to replace it. The wheel had broken into pieces somehow. I vice gripped the shaft on the one end and turned like heck and it was so darn stuck that a piece of the shaft broke inside the old wheel. NOW unfortunately I have to replace the motor. The wires were easily removed but I can't figure out how to get the motor out of the casing. Please help, I was trying to save money and I was proud I was doing it myself and now I am completely stuck!
  • justamom Nov 29, 2007
    I am way past all that. My problem is how do I get the motor out.
I access the motor to replace it but can't seperate it from the fan wheel.
Posted on Jan 09, 2008
  • 625 Answers
You need to pretty much disassemble the whole machine. the top cover comes off, the front panel with door comes off. the drum lifts out to access the motor as it is bolted to the floor.
Posted on Nov 29, 2007
  • THOMAS MIERZWA
    THOMAS MIERZWA Nov 30, 2007
    please go to this site and type in your model number. www dot partselect dot com. they will present you with a diagram of how your machine is put together. you are looking for the motor/blower so just highlight the motor and the site will give you an exploded diagram of how that part is installed.
SOURCE:
How do I get the old motor off to replace it if it is stuck
Remove the front blower cover assembly. Remove the round retaining clip on center of blower wheel. Pull blower wheel off motor shaft. Remove belt from motor pully. Pull out dryer drum. Remove clips holding motor to base frame. Remove motor assy. Easy peezy. Reassemble in the opposite manner.
Jun 21, 2014 | Whirlpool LEN2000PW Dryer
I can't get the motor shaft off the fan
From inside dryer hold blower wheel with wrench that fits the squre part of blower wheel turn motor shaft clockwise should loosen the blower wheel............
Jun 21, 2014 | Whirlpool LER5636P Electric Dryer
How do you get the motor off of a whirlpool dryer? We are trying to replace the bulkhead, but can't get the motor and blower separated
The blower will be held to the motor shaft by one or two allen set screws. Loosen these screws and the motor will pull out. the blower fan will drop down so make sure you can somehow hold it while you pull the motor away. Obviously unbolt the motor from the chasis.
Hope that helps.
Jan 16, 2010 | Whirlpool LER6611L Electric Dryer
The blower fan is lose how do you tighten it up . Whirlpool Duet Dryer
Use a 3/4' wrench on the blower wheel and a 7/16 wrench on the front shaft of the motor. The threads on the rear shaft are left hand threads so make sure you turn the shaft in the proper direction.check the wheel for cracks,usually if they are loose they're damaged,
Dec 18, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Can't remove dryer blower wheel
I would start by taking off the top and checking the belt to see if part of it tore and is hitting the inside of the cabinet. I have not found a real good way to get the blowers out without having to break them sometimes. the part of the blower that you have to hold is access through the front behind the motor. problem is when you turn the motor shaft, the wrench strips out on the blower, then you have to break them, but unless you need a new motor, it should not have to come off.
Jan 27, 2009 | Whirlpool Dryers
Can't remove motor from Whirlpool dryer (LER3624EQ1)
no set screw,,,put the motor back,,,put the motor clip back on...lock it back down...ok now take a wrench and put it on the end of the motor where the belt goes,,if your by your sef,,prop the wrench againt the inner cabnit wall,,,than turn the blower wheel its hard but it will come off you..just lock that motor shaft down,,grip pliers..wracket,,,please use glovers to turn blower wheel..housing is very sharp..onthejob
Jan 24, 2009 | Whirlpool LER4634J Electric Dryer
Tring to get the fan off of the motor on whirlpool dryer
nothing,,you should have keep motor clipped down,,and first remove blower wheel its just screwed on the front side of motor,,put motor back hold the end of motor with wrench,,than turn blower wheel..onthejob
Cannot remove blower from motor shaft
It does unscrew although at times they do stick. I would find a flat spot on the motor shaft and get a crescent wrench on it and lodge it so it doesn't move and then grasp the blower wheel and turn to remove.
Oct 16, 2008 | Whirlpool GGQ8831L Gas Dryer
Blower moter fan
Before attempting to remove blower, run the motor and note the direction of rotation. The blower wheel can be very difficult to remove. It is screwed on to the motor shaft opposite to the motor rotation such that every time the motor starts, the blower wheel gets tighter. The best way to remove, is to put an adjustable wrench on the blower wheel (from the motor side) and using another wrench or locking pliers on the side of the motor shaft where the belt goes. Rotate the motor shaft where the belt goes, in the opposite direction of normal rotation while holding the wrench on the blower wheel. It will be VERY TIGHT. If unsuccessful, the only alternative is to strike the blower wheel REALLY hard and break it off. GOOD LUCK!
If you need further assistance, let me know
Regards,
reg501
Jul 07, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool gas dryer1
have to lock down the motor shaft with vise gripe or pipe wrench .. turn blow wheel clock wise to unscrew it from the shaft
Nov 05, 2007 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LEQ9858P Electric Dryer Logo
274 people viewed this question
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
