Question about JVC HD-56G886 56" Rear Projection HDTV
I have a 27 jvc tv
I have 27 IN. JVC TV I BOUGHT IT IN 2001 HAS A GOOD PICTURE BUT THE PART IN THE BACK OF THE TV , WHERE YOU CONNECT THE CABLE TO JUST FELL OUT CAN YOU TELL ME WHAT HAPPENED CAN IT BE FIXED AND NOT COST ME AN ARM AND A LEG TO FIX? PLEASE RESPOND DONT WANT TO PURCHASE A NEW ONE IF I DONT HAVE TOO mamagypsy @aol.com
Gahanna ohio 43230
The connector that just fell off when the cable was pulled will have to be replaced by a service center, Sometime the connector will just come out ot the solder joint and can be replaced. Sometimes it breaks off part of the circuit board, if it broke the board it is not likely that anyone will be willing to try to fix it.
Posted on May 11, 2008
Getting tv sound from home theater speakers
Connect your sound from the cable box out to the JVC theater audio in jacks. This will give you sound through the speakers.
Jan 29, 2014 | JVC TH-C50 System
I have a jvc av-28wft1eks i can see the picture
well take the back off on the transformer should be two adj. pot screen control on top focus on bottom normally try to turn up screen control good luck
Apr 02, 2009 | JVC AV-27530 27" TV
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
Mar 24, 2009 | JVC AV-27920 27" TV
JVC RX-888V hook up to cable box - no video
There is some sort of setting you need to change on the JVC receiver. I had this same problem, and I read the manual and it solved it. You need to press and hold down a button to change the mode. Your unit probably says "TV Sound" right now. Once you press this button (not sure what button) like the manual says, the display should change to "DBS" and then it should work just fne.
Mar 20, 2009 | JVC RX-888V Receiver
Cable went out yesterday, when came back their was no picture or sound. green light flashing on timer. jvc av 27230 27" tv
did the input line still work, for the cable input do an auto search channel to reset your tuner, if it didn't work stop right there your tuner is mabye out
Feb 20, 2009 | JVC AV-27230 27" TV
Blue screen
bad connection but where need tech.
Nov 27, 2008 | JVC AV-27D302 27" TV
I just bought a JVC THD50 surround sound system. I want to hook up the system to my television and cable so when I watch cable I can hear the surround sound. I bought a digital optical audio cable and...
See below for the correct setup to get the best clarity sound possible.
From Set top box:
  1. Audio: optical or digital coax cable output --> jvc system Input
  2. Video: hdmi output--> jvc system input
From JVC System:
  1. Video: HDMI output---> TV HDMI input
TV:
  1. only accepting HDMI input from JVC System.
This will provide you will sound from your jvc system at all times. Your JVC system is made to be used as a hub. So essentially what you are trying to do is connect all components into the JVC system. Then only connect the video portion to your TV. The TV itself should NOT be emitting sound.
Note: You may need to turn off the speakers in the TV setup menu to acheive no sound from the TV. This will make for the ultimate experience.
Apr 03, 2008 | JVC THD-50 System
Jvc tv
Before confirm the picture faulty go and the select the blueback option ON in menu option. Disconnect the cable signal and check the tv displays bluescreen. If it is there picture tube will ok, fault in C board. May be dry contact in blue output section the picture tube conducts heavily the respective color.
Sep 14, 2007 | JVC AV32F577 32" TV
TV/Cable will only play after inserting DVD
ya service is better its lose connect the tv controlpower
Dec 27, 2006 | JVC AV-27D303 27" TV
JVC HD-56G886 56" Rear Projection HDTV Logo
138 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
