I just finish hooking up my amp and it works and sounds pretty good. When I turn the key I hear a small popping noise from the speakers what is wrong? Also is it normal for the amp light to be on after I remove my key?
The amp is supposed to turn on and off with the head unit. The remote wire on the amp should be connected t othe amp control/power antenna wire of the head unit.
The pop should go away when the remote is being switched on with the head unit.
If the amp is staying on with the key removed, it will drain your battery. You need to re-wire it so you don't get stranded.
My amp got very hot today. No smoke, but smelled like bleach, then like new plastic (like a new...
(More)
My amp got very hot today. No smoke, but smelled like bleach, then like new plastic (like a new shower curtain). Seems to work, but it is still very warm to touch 15 mins after I shut the car off. Any ideas?
hi, I have a citroen synergie 2lt hdi with a webasto cooling system heater and would like to find...
(More)
hi, I have a citroen synergie 2lt hdi with a webasto cooling system heater and would like to find the wiring diagram for it, as its on the blink, checked all fuses but there's nowt in the handbook. cheers.
