Question about iLO DVDR05 DVD Recorder
Connect ILO DVDR05 to a digital set top box tuner
Maybe I'm conceptualizing this wrong, but... my digital cable set top box controls my channels, I just want to setup my ILO DVDR05 to record whatever channel the cable box is set to. My VCR and TV both accessed my cable box via channel 3. How can I tell my ILO DVDR05 that I don't want to use it's tuner, but instead just accept (and record) whatever it gets from the cable box?
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Posted on Aug 27, 2008
SOURCE:
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Is my ILO 42" "EDTV" plasma ready for just a regular antenna?
No, it doesn't have a digital tuner. If you want to watch digital channels you will have to acquire a digital set-top box and connect it to the tv thru the av inputs.
Jan 16, 2010 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Cannot get new digital signal to my ilo tv
I've done a little research and I don.t see where you have a ATSC tuner that receives the over the air digital signal. You have a basic Analog tuner. The only way you can receive digital is by a HD cable box by having cable or going to Satellite.
Jun 14, 2009 | iLO 3200 32 in. LCD Television
Recording on DVD using converter box
I have my video outs from the converter box going to the inputs on the ILO recorder, and then from the outs on the ilo to the ins on the tv. Yes, box must be on and used to tune in what I want to record. I have successfully recorded this way. I never use the timer on the ILO anyway, it never works so If you want it to change from one channel to tape another you will have to be there. Also one of my box automatically turns off at a set time on non use so that is another problem. Maybe the newer recorders are differently programed but most cheaper ones don't have tuners in them so I assume they are about the same as what we have. Mostly for people who have paid tv now I guess. I refuse to pay, converter box is great.
Sep 16, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
No picture
I have my television outputs connected to the inputs on the ILO. I then select that set of inputs with the SOURCE button rather then using the built in tuner. Make sure you connect the Video closest to the audio inputs(or... least confusing, try the three front inputs) Hook antenna to tv
Jun 28, 2008 | iLO DVDR05 DVD Recorder
Ilo
I have the same problem when using the coax hookup. try using another input and see if that helps, I no longer use the tuner, just hook my tv up to the inputs and set the tv on what I want to record, same with vcr tapes etc.
Jun 07, 2008 | iLO DVD Recorder DVDR05
Catching one Channel Only
A TV card probably wont be able to tune it in...or decode(decrypt) it for that matter. Is a CableTv set top box plugged in? (the box your cable company supplies you with) -damian
May 01, 2008 | HP Expresscard TV Tuner For Windows Vista...
Can't record from tv or disc,
shouldn't need one, If you can't get the tuner source of your ilo to record, try using A/V cables (output) from tv to (Inputs) on ilo. set tv on channel you want to watch and it should come through to the ilo (selecting the correct source input of course) If your tv is really old and doesn't have A/V then you will need RF Modulator. This way of hooking tv up will also work with recording DIGITAL signal from a Digital converter box type tuner (the tuner in Ilo soon to be no longer operatable).
Mar 30, 2008 | iLO DVDR05 DVD Recorder
Dvd recorder
Following the instructions on hooking up the cables gave me fits. I finally just put the instructions away and winged it. Got it that way. Bypass your Ilo tuner. Hook the Comcast Cable (outs) up to the A/V input 1 of your ILO. Hook your tv combo A/V outputs, to the ILO A/V inputs. Select the Source and choose the cable source for cable and the combo source to tape from your VHS/dvd combo. Its a pain but you have to select Source everytime you turn the Ilo back on. You could hook your Cable to the ILO but would have to turn on ILO everytime to watch tv. Two remotes is a chore but you have to use tv remote for the volume anyway so it doesn't matter. Hope this helps.
iLO DVDR05 DVD Recorder Logo
198 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
