Question about Dell E173FPb 17" TFT LCD Monitor
Flat Panel Monitor the power button flash
When I turn on my Flat Panel Monitor the power button and the lower edge on the screen starts flashing. The screen doesn't display anything. I replaced Power and Monitor Cables , I connected the monitor to another computer that had the same flat panel... the trouble followed. I'm using a different and it is working.
    Novelist:
  • 138 Answers
Ok I got the same problem. And this is the way how to examine where the problem is. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 07, 2008
SOURCE:
WHY IS THE GREEEN POWER BUTTON FLASHING ON MY MONITER AND THE SCREEN THEN GOWS BLACK
When the power light is flashing the monitor is not getting a stable signal. This is hard to answer without direct troubleshooting. Check the cables first, make sure they are connected securely. If you still have problems test another monitor you know works or move monitor to a computer you know works, this will determine if the monitor is the problem or not and tell you if it is your "graphics port or adapter". If another monitor works fine, use the working cables to test the "broken" monitor. If you have an "all-in-one" computer, ignore the above steps and use a start-up repair disk. The reason this is hard to troubleshoot is there are so many things to diagnose. More than likely your "graphics card" is failing. These are some tricks to repair. You can update the driver, buy a graphic card separate from the stock port.
May 21, 2016 | Dell E172FP 17" LCD Flat Panel Monitor
Samsung lcd monitor power button flashes and wont turn on or off
I have the same exact problem. The monitor seemed fine yesterday. Today, the power button light just flashes on and off, with nothing on the display.
Dec 05, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Green light just flashes on and off and there is no displ
try to check your screen resolution maybe not compatible to your System. if green flashing there no signal from cpu to VGA cable monitor.
Jun 07, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Gateway fpd1530 15in flat
There are more than one inverter circuit for this model. One is prone to have poor solder connections in the transistors Q8 & Q10.
Another can be repaired by replacing 2 1uF electrolytic capacitors near the center edge of the board between the lamp sockets.
Monitor Mike
Nov 15, 2008 | Gateway FPD1530 15" Flat Panel LCD Monitor
The screen doesn't display anything and the power button is flashing green
Nov 30, 2007 | Dell E173FPb 17" TFT LCD Monitor
Dell E173FPb 17" TFT LCD Monitor Logo
52 people viewed this question
Ekse
Clive
Clive
