Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Lamp Replacement Problems for Hitachi 50V500A
Lamp burned out. Replaced. Like others, put on lamp cover - over and over - still blinking red light and no picture. Any solutions???
  • DawgInIndy Dec 02, 2007
    Having the same problem with new lamp. Put the old lamp back in and it works, put the new one in and keep getting the blinking red light. Assumed it was a bad new lamp and exchanged it. Same problem happened.
I'll tell you what I tran into and how it got resolved...
I experienced the same problem , with the blinking light...
Purchased a replacement lamp..
It didn't work(After market Universal supposably)..
Well..Come to find out.The Replacement lamp's housing looks similar, but the connecters that come out the back of the housing weren't quite long enough to trigger the microbe that activates the lamp in the Television.
Luckily I had the original lamp and it's housing that came with the television..
Took the bulb out of the new replacement lamp
Placed it in the original housing , and BINGO..It worked and is still working...
Posted on Jan 16, 2008
  • edwindog1 Dec 11, 2010
    I had the exact same problem - replaced the lamp housing with the new but when I turned the TV on again, the solid lamp light became a blinking light. I thought the replacement lamp housing connectors were a little short so I, too, took apart the housings, exchanged bulbs, put the old housing back into the TV with the new bulb and the TV works FINE! Thanks for your comment - I never would have thought to just exchange the bulbs, because the housing looked identical!!!! Happy Holidays! 12-11-10.
I found a solution to some of these problems. I too have a Hitachi 50V715 which started to become dim. I changed out the lamp(using the same enclosure ), installed it and the cover, only to find out the TV clicked once and clicked twice only to turn off leaving "lamp" light flashing. Getting frustrated I installed the old lamp only to find out it still would not turn on. I then knew it was an installation problem. Looking inside the housing of the TV ,in the upper right hand corner there is a small metal tap I noticed that pushes a blue"dip" switch. The metal tab was bent. I straightened out the tab .Also I took a small piece of scotch tape and used it to hold up the tab in an upright position. If you look at the back of your lamp enclosure you'll notice a plastic tab portruding in the upper right corner. This must push the metal tab which engages the blue switch behind it. Installed the enclosure and it "worked like a charm" ! I major problem was the tab was curved and just needed staightening. Hope this helps somebody else.
Posted on Mar 21, 2009
MY SCREEN HAS A BLUE STREAK ANY ONE KNOW THE SLOTION TO FIX IT THANKS
Posted on Mar 23, 2008
    Genius:
  • 1,694 Answers
I ALWAYS research Hitachi model # 's at www.HitachiServiceUSA.com gather info,go from there...T.
Posted on Dec 04, 2007
Ours was still under warranty when that happened and we had a tech come out who installed a larger fan from the original. We haven't had the problem since.
Posted on May 26, 2008
SOURCE:
My sony kv-36fs13 picture is very red. I tried adjusting the hue without success. I am getting the little red light on the front of the tv blinking five times. Any ideas?
open the back cover of your TV (unplug the unit) using a soldering Iron,resolder all the components at the CRT socket .the small square board attached to the tail of picture tube That's it! good luck and please dont forget to rate I need it to keep going...
Mar 08, 2011 | Sony KV-36FS13 TV
Replaced projection lamp and also cleaned out most of the dust inside the tv. will power on but shuts off before picture comes on tgen three red light blinks. please help asap. thank you.
Three red light blinks shows that lamp cover is not properly closed after lamp replacement. Make sure that the lamp cover is in its proper position. Try to reset the lamp cover and turn it on clockwise direction until you heard a click sound of a micro switch activated by the lamp cover, then put the set on..
Oct 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony LCD KF-50WE610 no picture-red light blinking
3 times standby red light blinking shows that lamp cover has not been placed back properly after lamp replacement.
Make sure lamp cover, (the first thing that you removed to replace lamp in tv) is fixed securely then turn tv On.
Jul 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Lamp replaced and the set doesn't come on.
Please make sure lamp cover is fixed properly after lamp replacement.
3 blinks shows that lamp cover is either not put back or not fixed properly in its position.
Thanks.
Nov 09, 2009 | Sony Televison & Video
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony kdf e50 a60 when TV is turned on picture goes off almost immedately and red light starts blinking in stand by mode.
Red light blinking is an indication of lamp problem. Check and secure tightly the following:
  1. Outside lamp cover
  2. Lamp door
  3. Lamp
If all of the above does not solve the problem, you need to replace the lamp. Let the lamp to cool for 30 minutes after unplugging. Use XL-2400 replacement lamp.
  1. Remove the outside lamp cover.
  2. Remove the lamp door.
  3. Pullout the lamp
  4. Hook a finger through the loop of the lamp handle and pull the handle upwards. Then pull the lamp straight out.
  5. Mount the new lamp securely.
  6. Reattach the lamp door. Turn the knob back to "CLOSE" and secure the cover.
  7. Put the outside lamp cover back in its place.
or visit http://www.fixya.com/support/t2631342-need_replace_42_in_sony_wega_hdtv
Aug 11, 2009 | Televison & Video
I have a wd65100 when powered on i get steady orange light then status blinks red & green,unpluged for 1 hour tv is working but dark picture
Hi
This issue can be due to ballast fan, lamp or high temperature. However, to figure out this we'll need to check for the TV from inside(wiring & testing the components) or the other way is when the lights blink again then follow the procedure given. After you turn on the set, and get the red blinking lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 4 flashes, then 1 flash = 41.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 28, 2009 | Televison & Video
I cant get a picture to display after just replacing the lamp
After replacement of lamp, please put back Lamp Cover securely as TV shows error of lamp cover (3 times blink)
May 07, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
4,198 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
