Question about Epson CX4200 All-In-One PSC Printer
Epson CX4200 All lights flashing: error says " shut off printer, remove foreign objects from printer, wait a couple minutes and then turn on the printer". I did that but the problem is still there. I called tech support and they told me to take the printer to a repair shop. Anybody have the same problem and have a fix for this besides a hammer ?
  • LucyDragoon Dec 30, 2007
    I have the same problem. It started after i had to give the paper a little tug to get it out. There is no paper left in the printer.
  • nadira23john Aug 21, 2008
    I have the same problem,I have an Epson CX 4200... serial # GTXY055784... all the lights are blinking , all the inks are full, no paper is jammed, i unplug it from  the power outlet wait and plug it back on ... same thing , the lights are still blinking .
    the printed don't make all the noise it used to when i turn it on... it's not responding to anything. Its a copier as well and it does copies without the computer . Now its doing nothing. Help me.
Well apparently there was a little tiny piece of paper stuck in there that I could not see. My computer tech found it and boy did I feel stupid.
Posted on Apr 01, 2010
I just Fixed the error of All Lights Flashing on my epson cx4200 printer.
Solution: I Totally unpluged the printer from 110 power source
then waited 3 minutes, then press the On button and let the printer run thru its normal noises during start cycle.
Originally I tried to just turn printer off with the off/on button but this did not ix the problem.
So make sure you TOTALLY disconnect the printer from the 110 AC power source.
Hope this helps.
Posted on Mar 31, 2008
General error L200, what is solution? I try to turn off and switch again...It Error again..
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. but not working printer.
Sep 30, 2012 | Epson L200 Original Continuous Ink Tank...
All lights flash on Epson stylus TX110
switch off the main power of printer in running situation and then on the printer.. hope it will be work..
Aug 20, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Ink light and paper light flash alternatively, printer does not work
Hi - According to the Epson manual that error indicates that paper may be blocking movement of the print head.
Turn off the printer, then open the cover and remove any jammed paper or foreign objects. Turn the printer on. If the lights continue to flash you're most likely going to need a dealer service.
Hope it's the paper.
Good Luck, Mikeywaf
Feb 28, 2011 | Epson Stylus C66 Inkjet Printer
Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. for epson stylus r 290
Feb 05, 2011 | Epson STYLUS R230 InkJet Photo Printer
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. how to solve this problem?
Nov 06, 2010 | Epson STYLUS R230 InkJet Photo Printer
General error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
general error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
Nov 24, 2009 | Epson Stylus Photo R300 InkJet Printer
Both red lights on my printer are blinking
Blinking wit general error message : head carriage error. It cause by head cannot move to parking position or chip at ink tank not good connected. Try to use another chip. Just turn off printer for a moment for clearing epprom.
Nov 09, 2008 | Epson Stylus C83 InkJet Printer
Printer will not print. error messge number 5100A paper does not feed
My Epson CX4200 was flashing error for apparently no reason. I was instructed to remove any obstruction, unplug, and wait several minutes before turning it back on. I could find no obstruction and the unplugging wasn't working. Finally I turned the machine upside down and shook it violently. This must have dislodged some particle I could not see because the printer now works fine.
Aug 10, 2008 | Office Equipment & Supplies
Foreign object
It appears as though the printer hardware itself is malfunctioning and will require service.
Apr 06, 2008 | Epson Stylus CX4800 All-In-One InkJet...
645 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
