Goldstar tv lock on
Somehow 'lock on' do not have remote control for this tv and cannot work out how to take of the lock. Unable to use the menu button on the tv due to the 'lock on' being present
  • 1 more comment
  • maxdorf Mar 24, 2008
    my maxdorf tv is lock what must i do to unlock
  • Anonymous Sep 10, 2008
    I have the same problem. How to turn the lock off?
  • Anonymous Apr 13, 2009
    SAME THING HERE. ANY SUGGESTIONS PLEASE?
3 Suggested Answers
SOURCE:
  • 119 Answers
SOURCE: FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Posted on Nov 03, 2006
SOURCE: nu tec crt 54cm tv
the problem is the volume/sound
Posted on Nov 06, 2008
I have a LG TV & need code for one for all remote URC3021B00
LG started out as Goldstar, merged with Lucky Corp., to become Lucky Goldstar, LG ;-)
Although your remote doesn't list any codes for LG, one of the Goldstar codes may work.
Try 0030, 0056, 0178.
If that doesn't work you may have to try the "Search for Code" feature by first turning your TV on, then follow these steps:
1.On the remote control, press TV once
2.Press and hold SET until the LED (red light) blinks twice,
then release SET.
3.Enter 9 - 9 - 1.The LED will blink twice.
4.Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5.To lock in the code, press and release SET.The LED will
blink twice.
The URC-3021 is a 2004 basic model without any learning capability, if you are unable to find a code, it may be time to buy a new remote.
There are newer, low cost universal remotes available at Walmart, Target, K-mart, and other retailers, that should have a more up-to-date code list.
Hope this helps, Greg
Jul 29, 2009 | One For All URC-9910 LCD Remote Control
Remote control code
Television Direct Codes for Sky remote:
Goldstar 065, 405, 318, 245, 275, 037, 060, 391, 137, 459
Here are the codes for GoldStar which became LG. They might be the same.
Good luck,
Techjoel
May 09, 2009 | LG Televison & Video
I have a rca remote control model RCR 450 and a GoldStar tv
goldstar television code: 004
press code search on remote
press tv on remote
enter code 004
press power on remote
Nov 12, 2008 | RCA Universal Remote Control
Goldstar tv remote codes
GoldStar TV 0030 0178 0019
Mar 05, 2008 | Televison & Video
Reset password
I found this on another question and the first method worked for my durabrand DU1301A t.v.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
Hold down MENU on the remote and VOLUME DOWN on the TV it?s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Comment by techman, posted on Feb 11, 2008 You need the original remote or an original replacement to use this procedure.
Thank you techman :)
Nov 28, 2007 | Televison & Video
Turn off child lock
To unlock the Panel Lock, Parent Lock, or Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Note: If you don't have a remote, you may be able to do the same thing by pressing the Menu button on the front or side panel of your TV and using the volume or channel up and down buttons on the TV to scroll to the Key Lock function and set it to Off.
Oct 02, 2007 | Televison & Video
FPA Lock
Nov 03, 2006 | RCA 14F512T 14" TV
Televison & Video Logo
392 people viewed this question
Top Televison & Video Experts
Ekse
