Question about Maytag MAH6700AWW Neptune Front-Load Washer
Maytag Neptune Front Loader - E2 error code
My washer is on and throughout the whole cycle it is continuously beeping and blinking the E2 error code. Does anyone know what this means? This code is not in the book. I'm hoping its not the same as the 2E one i had when the replaced the Electronic Control Board.
  • 4 more comments
  • Anonymous Dec 17, 2007
    MAF1300 has Error 2
  • ls99us Dec 26, 2007
    yes, we have the E2 error, it comes and goes.
  • Anonymous Dec 29, 2007
    same problem, what does it mean?
  • ShellZ Jan 06, 2008
    Apparently, the E2 code means a button is stuck on the touch panel. I had service come out twice. First one said he couldn't do anything because to test it, it had to be blinking the code - even though it did do it, he shut it off and then it wouldn't do it again. Second service tech was more helpful. He replaced the whole touch panel and control board, haven't had a problem since. Hopefully I won't my warranty is up at the end of the month...
  • zookeeper1 Feb 21, 2008
    I had the exact same problem. I had no idea what was wrong since the E2 code is not in the owner's manual. I've just turned the machine off and started it over. I haven't done anything yet to fix it since my warranty is over.
  • safiyahg Apr 18, 2008
    Maytag MAH6700AWW front load washer continuously beeps E-2 all through the cycle for no reason. No one has touched or pushed in any of the buttons.
The first time my E2 code came on the washer won't rinse or spin. I checked the drain pump to make sure it was working. (1) Take the back off and pull the two drain lines off pump. Be careful the line going to the drain has a backflow flap, make sure you don't tear it.
(2) On the other side where it drains from the washer to the pump is where I found a bobbie pin that had collected lint and was blocking the drain flow.
When it can't drain the E2 code comes on to let you know it won't rinse or spin.
Make sure to unplug machine before removing back,
Hope this helps everybody with E2 problems.
stude
[email protected]
Posted on Jan 09, 2008
  • stude Jan 14, 2008
    Another solution is if you have the E2 code you may have your water level set higher than your load in your washer. This will cause the E2 code and the washer will continue to add water, but will not rinse and spin out. We have had 3 sets of the different Neptunes and 1 set of Whirlpool. The Neptunes are the worst for this, we were thinking it could also be too much soap? Or a soap sensor?
    For the people who are having problem with water lying in the bottom of the washer. Do you use your washer more than 1 or 2 a week. If the pump is working correctly there should be no more than a half a glass of water left in the drain pipe right before the pump.
When I originally called maytag service they didn't know either, they had be down for a different code. However, when the tech came and called his tech support, the stated that it was a code meaning that a button had been pushed and held down for more than 30 seconds. The first thought my 4 year old had done it - I told him he didn't stay still for more than 30 seconds let alone hold a button. As for the vibrations with the drawer I can't offer much help as I don't have a drawer on mine. Maybe the load is heavier and off balance slightly? Or maybe it is slightly unlevel to do the attachment of the drawer or a loose bolt or something. I do notice that mine does move slightly though and every once in a while I give it a little push back to straighten it out. Not sure that this really helps you....
Posted on Jan 12, 2008
I have a Maytag Neptune washer, 18 months old. I have had problems ever since I got it with the E2 code. I had the service man out numerous times & he couldn't determine the problem. I called Maytag & they couldn't help me either.Thanks for the information..
My other problem is I have the drawers underneath the washer that cause a lot of viberations. Anything that is on top ends up in the back on the floor .It is so noisy.& it shakes the floor I have had the repairman out numerous times, but they haven't helped. My sister just bought a new washer & the salesman warned her not buy a Maytag. He said there are to many problems with some of the models. Can anyone help me with this problem?
SOURCE:
What does E2 error mean
Generic pump error
Error Code-control panel display "Err2" (Error 2, Error2) ' question ...
www.haier.com/za/help.../washing_machine/.../question/.../t20140313_209219.shtml
  1. Cached
  2. Similar
Mar 13, 2014 - Error message:Drain error, water can be not drained fully within the required drain time (controlled by PCB software). Reason 1. Pump filter is blocked. Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine). Step 1.Push a flat blade ...
How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front ...
9k=? 5:23 https://www.youtube.com/watch?v=by94vOVmmhQ
  1. Similar
Mar 18, 2017 - Uploaded by Nancy Gurish How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front Load Washer Stopped, Repair Of ...
Washing Machine Error Codes - Front Load and Top Load Washers ...
https://removeandreplace.com/.../washing-machine-error-codes-front-and-top-load/
  1. Cached
  2. Similar
May 5, 2015 - F9 followed by E1 - (drain pump system error) F5 followed by E2 - (door will not lock) F7 followed by E1 - (motor drive error) "rL" - (remove load) Washer making error beeps - Door has not been opened and closed for at least 3 cycles. Washer beeps when HOLD TO START is touched - Door not closed
Mar 22, 2018 | Washing Machines
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
Apr 22, 2016 | Maytag Washing Machines
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Haier HLP21n blinking light error code.. Rinse and Spin lights blink...what does it mean?
This washer is a sanyo on the inside. When panasonic bought out sanyo and all its daughter brands, they started making parts not available for repairs. The service manual is here---> https://panasonic.encompass.com/shop/research_new/HAI/sm/HLP21N.pdf
This is also known as a sears proflex among other names.... haier-hlp21n-blinking-light-error-code-eqln1e0r5dvuapuxoxy4lmrd-1-0.jpg
Dec 09, 2014 | Haier HLP21N Washer
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
5,355 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
