Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Help!! We put a new compacitor in the fridge and it is still making the humming noise. Does it supposed to do this for a while or the compressor is going bad? Is it hard to put a compressor in?
  • 2 more comments
  • sdthorne Nov 29, 2007
    One repairer told us to do this that advise me early this week. When you hear a humming sound it's the compressor?
    It is not cooling at all.
    It is running hot and the fan was running and the fridge is 4 years.
    The fan is running and yes it is dirty. How do you clean it?
IS IT HOT ENOUGH TO WARE YOU CANT KEEP YOUR HAND ON IT?
IS THE FAN INSIDE THE FREEZER RUNNING?
DID YOU CHECK TO SEE IF THE COIL ON THE BACK BY THE FAN IS DIRTY?
Posted on Nov 29, 2007
HOW OLD IS IT?
IS THE FAN IN THE BACK RUNNING?
IF YOU PUT YOUR HAND ON TOP OF THE COMPRESSOR IS IT WARM,HOT,OR COLD?
  • 80 Answers
IF THE COMPRESSOR GOES BAD THROW IT AWAY ITS NOT WORTH IT.Y DID YOU CHANGE THE CAP?
  • DAMIEN DOWLING
    DAMIEN DOWLING Nov 29, 2007
    PLEASE ANSWER ALL NOT 1 QUESTION AND THEN I CAN HELP YOU BETTER
SOURCE:
My American style Swan fridge freezer is making a loud humming noise it gets cold and still functions but the noise is drilling into my skull any ideas what it could be
It could be as simple as a warped fan blade, or an impending compressor failure. Since the fridge is working well, it would be _worth_ having a tech look at it. Fixing it now (before it fails) could save you the cost of a new fridge. Worst case scenario... You pay the man for his time to tell you the compressor is doomed. (Ask what their minimum charge for diagnosis is, before selecting a repair tech).
Apr 05, 2016 | Swan Refrigerators
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
The Ice Machine is pulling 40 - 50+ Amps on compressor startup, after 5 - 10 secs it trips the breaker. WHat could this be and is it easily corrected.
sounds like you need to change compacitor on compressor or your compressor needs replaced i would change compacitor first and if not helping then change compressor even if you buy compacitor and it doesnt help you still need to have a new one for the new compressor
Jun 20, 2011 | Franklin Industries Franklin Chef Ice Cube...
I have a small two-door whirlpool fridge which is the noisest fridge I have owned. Its a loud humming noise when it "clicks" on.
This sounds like the compressor is not healthy. The moving parts inside the compressor have become "tight" causing too much friction in the moving parts which you hear as a humming sound. This will gradually get worse untill the compressor completely fails.
A new compressor plus associated parts and labour will probably cost $550. It may be worth looking for a new fridge?
Mar 24, 2011 | Refrigerators
Should the wires coming from the run compacitor have power
The run capacitor is not a mechanical device, so the clicking that you are hearing is not actually coming from the capacitor. If you the wires going to the capacitor, (isolate the capacitor), you can check the microfarad rating of the capacitor to ensure it is still good using a multimeter. Hope this helps.
Apr 15, 2010 | Refrigerators
Compressor tries to kick in but then stops.
it is a hard start compacitor, the unit is not supposed to have three compacitors.
Apr 11, 2009 | Coleman Mach 15 Air Conditioner
Electrical noise
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
Apr 07, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Trio: humming and temp in freezer rising
It sounds like the condensor fan motor is seizing up. This is the fan that cools the compressor down. Does the outside of the fridge feel excessively hot to touch? Can you feel air being circulated under the fridge or behind the fridge? It could also be a faulty defrost timer. Try to identify where the buzzing is coming from and if it is the condensor fan you can put a normal standing fan behind the fridge, blowing onto the compressor untill the repairman can get to you.
Oct 29, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
