Question about Toshiba 36A61 36" TV
Click click repeatedly faded then red blinking light
Good TV for 6 plus years watching it and multiple clicks then a red blinking light. Now I have a green tinted picture. It is a good picture and good sound tried to reset and adjust color.No impact. What should I do?? Too good of shape to toss. i have some aptitude to fix but need a path to solve......HELP!!!!!
    Scholar:
  • 87 Answers
Go to the video menu and turn the color control to minimum. Determine if you have a black & white picture or is it green & white. If the picture is greenish, you have a problem in the screen circuit or possibly a bad picture tube. If the black & white is ok then I would suspect a problem in the chroma circuit such as a bad video jungle IC or a crystal. However, because your set had a red blinking issue prior to your existing condition I would lean towards the picture tube as the source or your troubles. You can try a simple test to determine if you have an intermittant short . Take the back off the set, and with the insulated end of your screw driver, very very lightly tap on the neck of the picture tube near the socket. If you see green flashes or hear loud snaps in conjunction with your taps or the green tint goes away, chances are the tube is the cause. If so, you might try installing an isolation transformer on the picture tube. Good luck
Posted on Nov 29, 2007
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
I have a sony projection television. I was watching it and accidentally cut it off. When I went I turned it back on it is not powering back up. I am seeing the red light on the front blink a few times and...
Hello.
My name is Russ. Maybe I could help you, but I need to know model number of your TV (it is located on the sticker at the back of your TV next to serial number of the unit). Also I need to knoe exactly how many times red light is blinking. It does it repeatedly. Foe example: six blinks, pause, another six blinks and so on.
Regards.
Aug 11, 2010 | Sony Televison & Video
MY TV DOESN'T TURN ON....POWER LIGHT BLINKS
power supply board is dead and needs to be replaced. very common problem.
Oct 30, 2009 | Samsung LN-S4051D 40 in. LCD Television
6 red blinking lights
You have a bad thermal fuse.
Oct 23, 2009 | Televison & Video
Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Oct 20, 2009 | Sony KDF-50E2000 50" HDTV
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
PICTURE WENT BLANK TV TURNED OFF
Replace the thermal fuse part# 1-910-006-44 You can verify this by jumping the connector where the fuse connects and the lamp will come on.
Aug 20, 2007 | Sony KDF-E55A20 55 in. LCD Television
Toshiba 36A61 36" TV Logo
118 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
