Question about Dell PowerEdge 2600 Server
CDROM and with a bootable CD is not been detected
The BIOS is detecting the cdrom but it is not detecting the Bootable cd I have in the CDROM
  • 3 more comments
  • t1993r Dec 30, 2007
    Already enabled the CD-ROM device in the Boot Sequence list of the System Setup. But still, PowerEdge 2600 still says "No boot device available."
  • dantes555 Sep 26, 2008
    It won't boot from CD ROM regardless of boot sequence in Bios. CD light is blinking during boot process but then: "No boot device available." Installation CD works fine in other machines.
  • Anonymous Oct 28, 2008
    I ma having the same problem. The CD ROM drive is not able to read the Windows Server 2008 CD because it is newer then the drive can reconize. I don't have a solution as of yet.
  • mmsa12 Jan 15, 2009
    I have the same problem in DELL poweredge 2600, as I can't use CD to boot up my system, also my CD is a valid bootable one, which have been tested in other computers.
    Also, I have choosed my CD rom to be first boot device in the SETUP menu.
    But with no luck, it is not detetced.
  • stoney66 Mar 24, 2009
    I have the same problem with my server's CD ROM! It's a Samsung SN-124. I've tried everything! Still won't read.... Help
    Problem Solver:
  • 7 Answers
Same solution as posted before if you need to boot from a DVD: take a Dell laptop CD/DVD combo drive, remove the screws and all and exchange the PowerVault CD drive unit with it. Same internal connector. Can't remember what model I stuck in, but I had to keep the front panel of the drive since it was slightly different, I probably could have glued it, but.... That's a server machine no one is ever going to see but me! :)
That also gave me a CD-Burner which is a decent addition in case you need to quickly burn a CD/make a backup/boot disk (like a "ultimate Windows CD" boot to fix anything that could go wrong).
Posted on Apr 03, 2009
  • none503 Aug 11, 2011
    take out the floopy/cd combo and disconnect the floppy connector. reassemble the cd in the cage and the bios should now detect the cd.
My problem was the the Dell Poweredge 2600 only comes with a CD ROM. I was trying to install Windows Server 2008 and it would do exactly what you said, just keep blinking and never find the CD. The problem for me was that the OS isn't on a CD, it's on a DVD. Double check this. My fix was taking the drive out of my laptop and putting it in the server. The laptop drive was the same size and connections, and most importantly it reads DVD's. As I type this, I am installing the OS behind me. GL
Posted on Oct 28, 2008
  • 25 Answers
Did you go into the system setup during the boot which is probably the F2 key. Then go to the bootup sequence and dignate the CDROM as the first boot device.
Posted on Nov 30, 2007
    Problem Solver:
  • 3 Answers
Finalllllllllly I have solved it.
Replace the CD Drive with any Laptop Drive, it is the same size and same socket.
and it is working fine now.
Posted on Jan 19, 2009
  • Ingrid
    Ingrid Dec 19, 2013
    thanks, this really helped !!!
  • 159 Answers
1) All early PE 2600 are CD drives (Dell did ship later vsn's of PE 2600 with a DVD drive, so a DVD drive IS available .. if you wnat to pay for it :-) )
To confirm, use any other bootable Windows CD (eg XP) .....
2) I recommend chuck out the useless Take Drive & use the empty bays for a pair of IDE or SATA drives .. and then buy a cheap PCI RAID card off eBay to use as run these 2 drives as your Operating System (Mirror)
A PCI RAID card with 1x IDE & 2x SATA is ideal
(as you can then fit a DVD drive to the IDE port and a pair of SATA HD's .. and then boot/install from the DVD ..)
The PERC RIAID is then reserved for your data store ..
Good luck !
Posted on Nov 29, 2008
  • Q4SteveB Nov 29, 2008
    Further ...
    The bootable Dell CD reqd. ISO image is OM_5.2.0_ISM_A00.ISO (from Dell site).
    For free ISO burner see
  • Q4SteveB Feb 09, 2009
    The TS-L462C combined DVD (reader) CD reader/writer is compatible (Dell even post the required drivers on the PE 2600 web pages :-) )
Dell Dimension 8200 PC Desktop Cd rom not reading disk
optical drive troubleshooting is pretty straight forward, fist see if you can boot to the drive using a bootable CD like the Windows CD or your Dell Resource CD, use the F12 1 time boot menu test it.
Also see if the drive is detected by model in the BIOS (F2 at boot) if not seen, reseat both power and data cables, boot to BIOS F2, turn on CAP LOCK SCROLL LOCK, NUMLOCK, then press ALT+E then ALT+F then ALT+B, this resets bios defaults and forces hardware re-detection. If you have no floppy diskette drive, you'll need to turn that back off in the BIOS before the ALT+B
If all that is done and the drive isn't seen/cannot boot to with bootable media, swap the data cable with the HDD and try a different power connection.
If Drive still not connected, replaced the drive.
If drive is detected and IDd then try this
Jan 28, 2011 | Dell Dimension 8200 PC Desktop
Can I boot my e-machine M6810 from a usb cdrom drive? My build in cdrom fell apart and my usb cdrom works when the computer is on, but I can't seem to boot from the new cdrom I have tried changing the...
in short - yes! any e-machine, or indeed any computer build in last 5 years can be boot-up from usb port.
you need to enter bios and setu-up as first boot-up device "other", "boot from another devices", i do not remember which one is actually in this particular bios
plug in your external usb cd-rom, or indeed bootable usb-memory or bootable hdd and they should boot and work as they are on the computer.
another issue, internal cd-rom cannot be really disabled as only mechanical, external part stop working, it' logic part is still there and cmoputer therefore "see" it. you can disable it by downloading newest bios which have bit more power and tweaks than old one.
Jul 26, 2010 | E-Machines M6810 Notebook
Upon reccomendation from a Microsoft tech and Acer, I have downloaded the current version of Bios update form my M5641, but have no istructions on how to perform the update. Please help
Ok, you must make a bootable DOS floppy diskette, or a bootable DOS CDrom if the machine has no floppy drive. You can download Windows executable DOS boot disk images here: I prefer DRDOS 7. There is usually a flashing utility and bios image file that you must copy to the floppy boot disk.
If your not very DOSSY, after the machine boots from the boot disk, you do a DIR, and find the name of the flashing utility. You enter that name at the command prompt: A:/. like this:
A:/flash_utility /h
That will give you help on how to use the utility.
But newer machines have smart bios that only need one file put on the boot disk, and everything is automatic.
Making a bootable CDrom requires special software that you must buy. Or you can use a Knoppix live CD, but you'll need one CD writer and one CDrom. It's ok if both are writers, or even if one is a DVD drive. has bootable CDrom image files. But I only know how to get files inside the image file using Linux. There are programs for Windows that can edit a CD image file. Google 'edit .iso file. And don't pay money. There are good freeware programs. One is called daemontools.
You must copy the bios file(s) to the CD image, and burn the CD. Then boot with it, and do like I described above.
Apr 20, 2010 | Acer Aspire M5641 PC Desktop
Cd rom does not show up in device maneger,wont
1.Check withBISO whether CDROM is there?
2.If shown in BIOS then set the boot priority to CD ROM and try with bootable disk,If booting reinstall the OS and If not then u will have to chthe CD ROM
Oct 12, 2009 | Compaq Presario Notebook
Cannot boot up in cd drive and will not boot up in ms-dos
You should set your boot up sequence to boot up first in cdrom in bios settings. Then load a bootable cdrom in your drive before booting up.
If this doesn't happen, cd disk non bootable or drive defective.
Apr 16, 2009 | Computers & Internet
First bootable device
ok first u have press the delete or F2 and go to the BIOS setting and sellect the first bootable device CD rom after save and exit.. after that u insert the cd of win xp. and install the win xp... if any problem cont me...
Apr 07, 2009 | Intel D945GCL Motherboard
Unable to boot win xp cd. not detected by compaq presario 5000 series interneal cd rom LTN 403 DQ24
Drive requires cd drivers to run Boot CD.
Some versions came with floppy disk to start cdrom drives, This will also require a floppy drive.
You may also try hitting f10 to enter bios setup make sure cdrom is bootable.
Mar 08, 2009 | Computers & Internet
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Nov 24, 2008 | IBM ThinkPad T21 Notebook
Cdrom not detecting
attach another drive to your system boot your system with bootable windows cd and make your system drive c
install windows in c drive
this problem is incounter
when u install the window in other drive than c
Dec 22, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Boot problem
Nov 07, 2007 | Dell PowerEdge 2600 Server
Dell PowerEdge 2600 Server Logo
3,033 people viewed this question
Alun Cox
