Question about Sony Handycam DCR-TRV25 Mini DV Digital Camcorder
Sony DCRTRV 25 : Getting 31:23 error message
I am getting 31:23 error message when i use my Sony DCR TRV25 . Any suggestions how to get past it ?
  • udevil Jan 14, 2008
    I'm getting the same error(c:31:23) error message and the tape is extremely slow to come out, repair is a $50 estimate to start .... Is there a cheap fix
  • andre62 Nov 23, 2008
    I have te same error (c:31:23) on my DCR TRV11.
    Initially a tape got stuck in the camera. After several tries and a little pulling the tape came out. Then the tape compartment doesn't want to go in anymore. I bought the maintenace manual to openup the camera to see what is blocking the mechanism.
    I fond some dirt (and a little leave) witch i removeed. Now the compartment opens and closes without a tape (sort of smooth).
    With a tape in the compartment it moves far slower. And shows the error while loading. The tape is fully in and the case can be closed though with the error on the screen. (sometimes there is no error)
    I belief the mechanical mechanism is damaged/worn-out(?). Is there a replacement (part) at sony for the complete mechanism deck?
    Or did anyone solve this problem?
    Thanks.
Andre62:
The error is code is for S reel fault. This is the left reel for rewinding the tape.
Posted on Nov 23, 2008
    Sergeant:
    Champion:
  • 231 Answers
Possible pinch roller problem.The pinch roller rubs against the capstan motor to pull out of the cassette .This pinch roller seems to fall completely or loose causing the error.The other possiblity is that the capstan motor is not turning ..might need repair..
Posted on Nov 29, 2007
SOURCE:
No installer CD SONY DCR TRV 250E digital 8 handy cam
HI
MY NAME IS ALI HABIL AMIRKHIZ FROM IRAN - TABRIZ CITY
I HAVE ONE CAMERA SONY DCRTRV 250 E
BUT I HAVE A PROBLEM IN THIS CAM AND IN HED
MY CAMERA SERIAL NUMBER : 291985
PLEASE HELP ME
MY ADDRES EMAIL : [email protected]
Mar 05, 2011 | Sony DCR-TRV285E Digital-8 Digital...
Sony trv25 cassette does not eject
These can have ls chassis failure causing the tapes to jam in the set. Can be repaired under $200 in most cases. Larry's Electronics 916-362-8708 [email protected]
Apr 22, 2010 | Sony Handycam DCR-TRV25 Mini DV Digital...
Sony dcr-trv25 when playing back tapes sound goes on and off pic sometimes distorted tried cleanig with tape still doing same thing I dropped camera from a standing position (3ft) nothing broke thats when...
Yes sounds as though the audio playback head had become misaligned by the drop... You will have to get it back in position again. Thats a job and a half though, really only something that can be done by a tech?
Feb 17, 2010 | Sony Handycam DCR-TRV25 Mini DV Digital...
Sony DCR-TRV25 when opening LCD panel turning upside down
my camera used to do that too as a matter of fact its just how some cameras are i used to be in a video class with cameras in high school and college , if you have to turn the lc panel the other way for it to work so the lcd panel must be turned away from you when your filming then to watch it you can turn it around i hope this helps you if not reply to me at Jonk3y @aol.com
Sep 23, 2009 | Sony Handycam DCR-TRV25 Mini DV Digital...
Problem with Sony DCR-TRV25 camcorder
Your code indicates that the supply reel is not turning or is not supplying a pulse so that the camcorder "thinks" it's turning. Hard to say why that's happening without seeing the camcorder. Is there a tape stuck in the unit?
Oct 19, 2008 | Sony Handycam DCR-TRV25 Mini DV Digital...
Can't find Driver for Windows Vista Home Premium
heres a driver for your camcorder to your vista os. if aint working using vista then get back to windows xp and it will work using that driver.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV25&LOC=3
according to this it is supported with windows vista but im not so sure. just use it on your own risk.
select an OS and download. install it to your pc and it should be working after that. hope that helps!
CHARCOIS
Oct 09, 2008 | Sony Handycam DCR-TRV25 Mini DV Digital...
TRV25 error C:31:22
try hitting it on the side kinda firm.
Feb 25, 2008 | Sony Handycam DCR-TRV25 Mini DV Digital...
http://esupport.sony.com/US/perl/news-item.pl?mdl=DCRTRV19&news_id=161
Jan 11, 2008 | Sony Handycam DCR-TRV25 Mini DV Digital...
Error code sony dcr trv25 c:31:23
Sony says the unit needs a power reset (error 31). Unplug the camera, remove the battery and wait several minutes before re-attaching the battery and/or AC cable. Then power the camera back up. The 23 code says you need to use a InfoLithium battery-- apparently these are smart batteries that give data back to the camera. These error codes seem to be quite common however, and so a hardware issue may be the case. Some users have said that removing the battery while the camera is powered on will clear the codes. Others advocate "smacking" the camera, I would not however, recommend this. www.sony.com is a good place to look for more information.
Nov 19, 2007 | Sony Handycam DCR-TRV80 Mini DV Digital...
Sony Handycam DCR-TRV25 Mini DV Digital Camcorder Logo
855 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
