Question about Toshiba 55H70 55" Rear Projection Television
Bad picture there are half moon lines starting at one side of the tv and going to the other side they are at the top half of the tv. They are red and green. the picture is black on the top of the screen about a inch,. Can someone please let me know if this is fixable and what the price range would be to fix?
  • 244 Answers
Try to consider the following tips:
Smearing out of one or several colors, best seen in txt-mode, my 27CE4599/30R smeared out in red and green, not in blue, fully exchanging the drivers (input and output complete, otherwise the RGB driver will blank the crt) moved the fault to the other color
Replace the 180K feedback resistors in the amplifiers with normal 1/4W metal film instead of 1/8W, they can become open circuited (in mine both green and red were faulty in this way). Change all 3 and not just the defective ones, replace also all the paralleled 75K resistors per color (fe by 47K+27K) to prevent bright color raster (they can also become open circuit)
Posted on Nov 29, 2007
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ... > Boards > Community Central > The Vestibule
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
Feb 03, 2016 | Televison & Video
Tv comes on but after couple of seconds lights goes off but sound stays ok
check the power board on the 24v side this is for the inverters.if fine then shine a light in one of the side hole in the screen at the back to see if you have a picture if you have a picture then check the relay on the power board is working its a black square there are 2 of them. when you turn on the tv you should hear click then click thats the power and then the inverter power. if you have 3 click that is the inverter power switch turning back off. if you not having this problem. then the 24volt side has a fault. would think off hand the 3 pin power chip its a half moon top. they are prone to over heat if they are next to the transformer. failing that there is a logic power chip 4 pin you will see a white line and the chip is crossing it. hope this helps.
Sep 23, 2013 | Samsung LE46M51B 46 in. LCD Television
Right half of screen black with thin blue line top to bottom about another line inch over another thin line starting blue then red getting thiner to bottom
This is a very common problem with this Panasonic set where half the right side is bad and the other half is good. This has been traced to a general plasma panel defect in the manufacturing precess. The panel lasts only about 1.5 years and they go bad. The only solution is to replace the plasma panel. The charges for the cost and labor will double the original prize of the TV set.Good luck.
Oct 27, 2009 | Panasonic TH-42PX60U Television
Hitachi projection model #43fdx01b.distorted color, blue off set. Half moon line at the top, taking top part of picture.
Ur convergence is dead.U need buy a convergence kit,U know how to solder right?Buy it at these websites.Tv Repair or
Sep 30, 2009 | Hitachi 43FDX01B TV
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Sony Kp65sw500
You have 2 IC's in the convergence circuit and possibly a micro fuse that needs to be replaced. Consult a local TV repair shop.
Nov 23, 2008 | Sony KP-57WS500 57" Rear Projection...
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
get an estimate to fix your convergence problem
Oct 08, 2007 | RCA P52937 52" Rear Projection Television
Top half of screen black
The vertical circuit is going bad,this is the one in charge of opening the picture up and down,try taping on the side to see if the picture reacts ,if it does your set has a loose conection and the vertical IC will need to be resoldered only but if it does not react the IC will have to be replaced,if you are familiar with tv service this will give you a place to start but if you are not be safe and seek the help of a servicer,please let Us know how it goes.
Oct 11, 2006 | Sony KV-XA34M66 34" TV
Toshiba 55H70 55" Rear Projection Television Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
