Question about Sony CFD-S300 Radio/Cassette/CD Boombox
Setting presets how do i do it?
Dial in station then hold down number button till the unit blinks then comes on and stays.
Posted on Jan 12, 2008
How to set stations on the directed hd radio dhhd-1000
First navigate to station you want to set as a preset. Then press the MEMO button. Use the TUNING buttons to scroll through the 30 different preset numbers. Press the MEMO button once more to store on the preset that you chose. Now you can press the PRESET button and navigate through you presets using the TUNING buttons.
Jun 28, 2013 | Cars & Trucks
How do I set the clock & preset the stations. I bought the radio 5/4 /11 & there was no brochures or warrantee in box.
Setting the Clock 1. Press and hold the CLOCK button until the hour begins to flash 2. Use the left arrow and right arrow buttons to change the hour. 3. Press the CLOCK button again. Use the left arrow and right arrow buttons to change the minutes. 4. Press the CLOCK button again to save.
PRESET Stations the PRESET stations: 1. Tune to desired station. 2. Press and hold the PRESET button until the PRE-SET indicator on the display begins to flash 3. Use the left arrow and right arrow buttons to select the PRESET location for the station. Ten locations (0-9) are available. 4. Press the PRESET button to save the location. To tune a PRESET station: Press and release the PRESET button to step through the PRESET stations.
May 06, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
I can't figure out how to set the radio station pre sets
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
Dec 24, 2010 | Teac CD-X9 Shelf System
Advice on how to set tuner presets on AlpineCDM 7838R in car stereo CD . Unit has both permanent and switched power supplies, will search stations and hold them when switched off but cannot work out how to...
some of the alpines had an odd way of setting the presets manually. you need to press any of the 1 thru 6 buttons for a few seconds. when the display starts blinking just pick which preset button (1 thru 6) you want to set the station at and press it once.
Aug 25, 2009 | Car Audio & Video
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Need operating manual for Zenith Model Z253W radio
1. Tune the radio to the frequency you want to preset, using the "Tuning/Set" buttons.
2. Press "Time Set" button to enter set mode. Note it says "Preset" below this button, because it is used to set both time set and presets.
3. Select the preset number you want, using the "Preset" buttons.
4. Press "Time Set" button again to exit set mode.
5. Repeat the above process for each preset.
Nov 15, 2008 | Zenith Audio Players & Recorders
Set Radio Station Presets
Try just holding the button of choice down. In my Audi, when I had a factory head unit, to set for example, preset 2, I'd just tune to the station I wanted to program, and then hold down the number 2 preset button until the display stopped blinking. It was then preset.
Oct 09, 2008 | 2001 BMW Z3
Front focus problem
Hey hubro,
This switch is used to set a focus point to so you can quickly focus to the preset distance. What you have to do is set the switch to the on or on with sound setting then focus to the distance you want to preset and then press the set button. While this switch is set to the on or on with sound setting you just turn the focus preset ring which should be in front of the focusing ring and the camera should focus to the preset distance. I hope this helps!
Go Ahead. Use Us.
Jul 20, 2008 | Canon Telephoto EF 300mm f/2.8L IS Image...
How to pre set satitions
Your Sony is equiped for 5 AM presets and 15 FM presets.
1. Power your unit "ON".
2. Set the desired band - AM or FM.
3. Hold the "Mode" button down no more than one second. The "preset" indication just be gone.
4. Manually tune in the desired station you want to preset.
5. Hold "Enter" until preset indication re-appears. The number of the preset should be blinking.
6. Using the tuning buttons, change the the number to your desired "preset" number.
7. Push the "Enter" button to set the preset.
Remember, you can't have more than 5 AM presets (a mistake I made).
Jul 16, 2008 | Sony Walkman SRF-HM33 AM/FM Radio
How to set a station with the remote control
1 Tune in the station you want to preset..(use >> >>
Aug 11, 2005 | JVC FS-2000 Shelf System
Sony CFD-S300 Radio/Cassette/CD Boombox Logo
87 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
