Question about Avanti FF1101W Top Freezer Refrigerator
AvantiFF1101W Refrigerator not cooling
The freezer is still working, but not at the usual high capacity as before. How much will a new motor cost me [if that indeed is the problem]? And by the way, A PC Richards salesman told me that Avanti has been taken over by Summit and tried to sell me one of that brand's energy saver models. What's the deal with that?
    Habit-Forming:
    New Friend:
  • 46 Answers
Generally when refrigerators don't cool enough it is usually down to blocked cooling grills found at the rear or the underside of fridge, if you clean the dust off these grills you may find it works ok, hope this helps.
Posted on Dec 02, 2017
4 Suggested Answers
  • 340 Answers
SOURCE: Avanti refrigerator not cooling
thermostat set ? might not be defrosting all the way. damper actuator not opening from freezer to refrigerator. is the condenser clean?
Posted on Jun 17, 2009
  • 1218 Answers
SOURCE: Refrigerator model 309YBT quit working on Friday
Good day,
You did not say if it was running or not.
If not running at all, then it may be the cold control, (thermostat) that has failed. You can remove it, jump the 2 wires going to it, and see if it runs and cools.
If so, you may be able to contact your local appliance parts house for a replacement.
However, if running and not cooling, then 2 options.
1. If under 5 years, sealed system should be under warrant. Call your selling dealer for details.'
2. If over 5 years, not price effective.
Posted on Nov 16, 2009
heatman101
  • 43501 Answers
SOURCE: My Avanti refrigerator/freezer model #FF511W/FF512PS
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 10, 2011
Samsung RB31F Fridge/Freezer - fridge temperature too high, freezer OK
1-The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty-if the condenser coils are dirty, clean them.
2-The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Oct 29, 2017 | Samsung Refrigerators
1998 GT22DKXGN00 refrigerator freezes, where is thermostat in refrigerator ? This is a Whirlpool
Check refrigerator and freezer temperature. If the freezer is above 0 degrees Fahrenheit it is likely the cooling capacity of the unit has reduced due to low charge or weak compressor. What usually happens is that the freezer is not able to reach the proper temperature and the unit runs continuously. The result is that the refrigerator via the freezer-refrigerator air flow connection freezes.
"This is not intuitive", but the logic is that from the compressor running continuously the freezing air that flows into the refrigerator side results in that the refrigerator will freeze,.
Check the temperatures. If the freezer is above 10 degrees F it is almost certianty the cooling capacity has been reduced.
If equipped with an ice maker the output of the ice-maker will also reduce with this problem
It is possible to have the compressor replaced but not usually cost effective.
Apr 10, 2017 | Refrigerators
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
Not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
uy4
Jul 14, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Whirlpool model ed5chqxkbo1 wont cool
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is usually the evaporator fan motor ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore 22' bottom freezer model 596.77275790 isnt cooling in the fridge and the freezer seems to be working but there is alot of frost on the back of the freezer,I turned the fridge as high as it would go...
Sounds like the freezer/refrigerator ciculating fan is wearing out, this fan supplies the circulation for the freezer as well as the refrigerator. When is starts to wear out the rpms are reduced to a point that it will keep the freezer cold but not the refrigerator. The minimum cost to replace this fan is around $300.00
Jul 11, 2009 | Refrigerators
Kenmore refrigerator cools on and off
can you help me to resolve it. the model #596.52673200 Kenmore made. I replaced the defrost thermostat years ago. It works after that, now it has stopped working. I replaced another defrost thermostat and pull my refrigerator away from the wall, after it works, I push back to the wall where it was, it stopped working.
Finally, I turned the thermostat off for an hours and back on, then it works again with pull it away from the wall. what is it problem?
it will stop again. on and off. can you explain the possibility?
thanks
Luis
Feb 15, 2009 | Kenmore Refrigerators
Freezer comparment will freeze OK, but fridge does not get cold.
If the freezer is working properly, and the fridge is not, it is usually the evaporator fan. It should be located behind the back panel in the freezer. Usually, a fan blade is stuck, or the motor is stuck on it's bearing. You may need to reposition the fan or apply some oil to the bearing. If you cannot get the fan to spin, you might need a new fan motor. Check the voltage first before buying a new motor. You should get around 110V AC .
Dec 31, 2008 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
Avanti FF1101W Top Freezer Refrigerator Logo
69 people viewed this question
Top Avanti Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
