Question about RCA RS2000 CD Shelf System
RCA RS2000 CD Shelf System - CD Cover Latch
The CD player cover would no longer stay down on my unit. I disassembled it and the latch appears to longer work. It's a black plastic mechanicle device identified as "Lx2". Does anyone know where I could buy a replacement?
    Novelist:
    Champion:
  • 244 Answers
I was recently work on researching your item in the internet, and I was not able to found any supplier of this item or accessories. This only an advice, you can check the supplier where you bougth the said player possible they can give you any appropriate feedback regarding your problem. I am hoping that this will be a helpful information to solved your problem even though I was not able to solved your problem.
Please don't rate me until such other fixya will able to post their own opinion regarding your problem. Thank you.
Posted on Nov 29, 2007
SOURCE:
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
RCA RS2000 Shelf System CD lid latch
you could go to thrift store and check cd players there .Alot of those latches are the same.Take old one and try to match it there.and throw the rest .LOL .Better than ordering and waiting or sometimes it only comes with complete door.But if you have to order try andrewselectronics.com, partstore.com or vancebaldwin electronics..
Dec 06, 2007 | Audio Players & Recorders
Lost audio in system after power loss to house
Hi James,
Please confirm if your brand and model no. is RCA RS2622, this is printed at the rear cover of your unit, manual and on the receipt.
Mjsazon
Nov 28, 2011 | RCA RS2622 CD Shelf System
Top shelf that covers the sub zero fan fell off
line it up with the posts on the ceiling of the refrigerator with the hooks down when it is even on both sides push it back about 3/4 of an inch and latch the clips. if you look at the side of the cover you will see the notchs on the sides of the cover. hope this helps.
May 05, 2009 | Sub-Zero 690 Side by Side Refrigerator
Manual showing how to remove DVD-ROM Drive from case for Presario 5000?
REMOVE CASE SCREWS FROM REAR CASE COVER.CASE COVER SLIDES OFF FROM FRONT TO BACK.DVD IS HELD BY 4 SCREWS TWO PER SIDE DISCONECT POWER LEAD AND RIBBON CABLE YOU GOT IT,RICHARDM69
Dec 02, 2008 | Compaq Presario 5000 PC Desktop
I have a RCA RS 2000 minibook shelf stereo and I can not find part I need the black latch that holds the CD cover down so the CD can play ,It is located at the right front under the CD cover,it is about 1...
There are actually two types of this latch available. Can you tell if yours has a switch in it? You can tell if you can see the bottom. The one with the switch has 2 wire tabs on it.
Dan
Sep 30, 2008 | RCA Audio Players & Recorders
Memorex CD Clock Radio # 2863. Broken latch .. will not hold down top cover
Also have the same problem, clock sat on the night stand for a couple of years. Wife took into work to play CD's at the Christmas Party and the latch failed.
Think we may have used it once or twice as a CD player.
The black latch was easy to remove, justed open up the radio and pushed in the ears on the latch and it slipped back up into the CD compartment.
Will see if I can find something to repair it. Looked like the side cracked and a housing lost some of its side.
Feb 10, 2008 | Memorex AM/FM Clock Radio with CD Player
RCA RS2640 Quit
Unit probably has defective component in standby circuit. Have serviced
Jan 15, 2008 | RCA RS2640 CD Shelf System
CD Player
Thank you for your reply.
BeoSound 2000 - The CD won't even spin now. The cover closes, the Number 1 for the track appears in the display, then the cover immediately reopens showing what looks to be something like this [ ] in the display.
Nov 14, 2007 | Bang and Olufsen Beosound 2000 Shelf...
RCA RS2000 CD Shelf System Logo
96 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
