Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
No picture on Samsung HLN5065W
Our HLN5065 went out a couple of weeks ago; picture went dark with a pop, sound was fine. The center green light (lamp) flashes, and the set won't shut off, seems to be recycling itself, have to unplug it. Also, there is a high pitched humming. We ordered a replacement lamp, but same symptoms exist (sound ok, no picture, won't turn off, high pitched humming). Please help...
  • 2 more comments
  • som_one Nov 29, 2007
    Additional information by som_one:
    After the set "recycles" a couple of times (turns itself off/on) it acts like its fuctioning, but no picture and all 3 lights blink. Should be a bulb with that symtom alone, but we tried to fix this with a replacement bulb.
  • wazzu11js Dec 16, 2007
    Mine did the same thing tonight. Turned it on....then heard a pop, then picture went very dark. I could faintly see the picture but very dark. I unplugged all power to recycle and now mine does just like this persons. Sound is fine but no picture at all. I have pulled the lamp (bulb) and see fine pieces of grit inside the lamp itself. I'm assuming this is bad but can't confirm like a normal light bulb (filament is still attached). I looked up specs and found that the lamp should be a BP96-00224J (I think), but I actually have a BP96-00224C in the set. I had warranty covered issues with the picture within the 1st 9 mos of ownership (TV is less than 4 yrs old) and the tech replaced the "light engine and adjusted". Whatever that means. I hate to pay a tech to come out to change a light bulb. I'm thinking that I should order the part (curious which part # though), and give it a try. Does anyone know which part # is correct and want to weigh in with advice? I'd appreciate it. Here is my info:
    Model # HLN5065W
    Model Code is HLN5065W1X/XAA (whatever that means)
    SER # 31DX300620M
    Manufactured March 2004
    I have a 45" mistubishi that I bought in 1995. Not 1 service call, still running strong. Should've stuck with a proven manufacturer.
  • Anonymous Feb 18, 2008
    No Picture on Samsung HLN5065W problem: Same indications - picture went out, 3 lights blinking, had to unplug it.  Then recycling on for 1-2 minutes (1 light blinking) and then turns off and then on again and repeats.  Prior to this, I have had a loud color wheel in the past few weeks on three occasions.  From what I can gather its probably the wheel.  SEE link below for an excellent treatment of color wheel replacement & saving of $400-500 cost (I will be trying this if the bulb replacement does not remediate the problem).
    How To Replace the Color Wheel in Your Samsung DLP Television and Save $400 | Jangro.com
  • thamastermel Sep 23, 2009
    I have samsung hln5060.Couple weeks ago it started turn on and off few times and then stayed on. Now after 5 min watching picture starts to lose colour and then it and it starts "jump" from left to right and i can see 3 same picture on at the same time
    New Friend:
My hln5065w 50" samsung tv started flashing where the bright partof the pictures were and progressively got worse. So I bought a new bulb for it and it worked a few days and started doing it again with the new bulb. It seemed like the bulb was getting hot so I opened it up where the bulb was and put a little fan I had and poited it at the bulb. It helped for months but now it's flashing real bad and nothing helps. Does anyone know what could be wrong with this thing? Any help would be greatly appreciated.
Posted on Aug 13, 2010
  • 179 Answers
Sounds like the color wheel has gone bad..the part is not very expensive but it takes some work to replace it
Posted on Nov 29, 2007
4 Suggested Answers
SOURCE:
  • 336 Answers
SOURCE: I have a Samsung HLR5067WAX/XAA 56 inch, rear
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Here's the instructions to replace it http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php and your part # is BP96-01103A Have a bless one!
Posted on Apr 26, 2010
Testimonial: "Thank you! "
ladywinn
  • 5138 Answers
SOURCE: Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
Posted on May 01, 2010
ladywinn
  • 5138 Answers
SOURCE: Samsung HLN5065W will not start up. Goes through
Ballast Board ,it connects to the Lamp which is what Powers Lamp on.
First check all fans Lamp fan,ballast fan,DMd Fan, if they are OK then replace the ballast Board.
Encompass Parts Distribution 1-800-638-3328 Go to their website they have Free Service Manual
that you can print out for this Model.
Posted on Jan 20, 2011
Testimonial: "THANKS FOR THE ADVICE. I WILL TRY THIS AND SEE WHAT HAPPENS. "
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
The picture on my hln5065 w is rolling, yet the picture in picture in fine.What is the problem?
In order to have a PIP you have to have two receivers in the TV. The receiver for the main picture is failing.
Jan 29, 2011 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W will not start up. Goes through 3 cycles and then lights in center circle blink. A new lamp was installed 2 months ago and it worked fine. The first time it didn't start-up, I unpluged...
Jan 20, 2011 | Samsung HLN5065W 50" Rear Projection...
Last week , my 6-7 yr old Samsung hln5065w dlp tv went blank. When I turned the tv back on after trying to reset it there was a winding noise but no picture. I replaced the lamp and still no picture. The...
Sounds like the old lamp blew and took out the ballast. I believe that you need a new ballast for your unit. The other possiblity would be a problem in the low voltage power supply but if the indicator lights are blinking the most likely problem is the ballast.
I have a tip at http://www.fixya.com/support/r4977572-when_change_ballast_in_dlp_tv which explains the problem, how to repair it and where to get the parts. If you need more help let me know.
Thanks for using FixYa and the generous rating.
hardrocko
May 28, 2010 | Samsung HLN5065W 50" Rear Projection...
My 44in rca dlp picture is black and is making a humming sound
It sounds like to me theat the new lamp is faulty. If there is any pieces of glass in the lamp compartment, remove them so they will not travel and get wedged in places they should'nt be.
Hope this helps,
Skyassoc
Jun 16, 2009 | RCA Televison & Video
Samsung HLN5065 DLP TV - Turns on, have low quality picture
you have a bad color wheel replace it yourself its easy part is 95.00 plus s/h
May 26, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung hln5065 picture issue
If all 3 lights are blinking on Samsung DLP it means your lamp is burnt out or has issues. The manual says replace the lamp when all 3 lights are blinking. If you can hear the arc from the ballast the lamp should light if the lamp is operational.A new lamp should solve your problem.
Mar 01, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
511 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
