Question about HP DVD 740VI 16X16 Dual Layer LightScribe DVDRW Blk RTL (HPDVD704VI) Burner
Hp 740 does not recognize dvd at all
The last two games I have tried to install, I cannot because the cd rom does not see that there is a disk in there. My other disks work. But my new games do not. What is up with that I have an AMD 64 3000+ 1.8 ghz 512 mb raml Nvidia graphics card. Help.
  • jniffer Nov 29, 2007
    If this is the case what do I do??? The games are sim city societies and hospital tycoon. My other new games work fine like the the sims etc. So I do not understand the problem. I have another disk reader installed, my old plexwriter 40/12/40A and it does not see the game cd either. My video card is NVidia G force FX5200.
    The game required window xp SP2 or vista
    1.7 ghx intel or amd xp 2100+ or faster
    512 mb ram
    Direct x 9
    Video adaptor 128 mb
    nvidia 5900 or greater for windows xp
    I have Windows xp (don't know what the sp2 means)
    1.8 ghz AMD 64 3000+
    512 mb ram
    Nvidia Gforce FX5200
    This what happens: I boot up, put the game cd in and wait. No install screen, even when I go to my computer, it does not recognize anything in the cd player. So, is it a drive r problem? I am very confused. My new Sims add on works fine.
  • 456 Answers
Your two game cds have sofware recognisation problem with your pc's operating system as well as your nvidia graphic card.
plz check that these 2 cds have special requirement about nvidia graphic card, looks like the graphic card does not recognise your games at all. If you use HP 740 it has firmware problem which sometimes recognise so cds with the matching firmware. i hope this make sense.
Posted on Nov 29, 2007
  • 1 more comment
  • Zaid Anarwala
    Zaid Anarwala Nov 29, 2007
    check out your cd case it has mentioned that whar are the game requirements check out that first and tell me the configuration of both may be try it on the same other pc any nearly person of you.thanx
  • Zaid Anarwala
    your graphic card is not able to load graphics so thats why that problem is occuring.your graphic card is 5200 and requirement is 5900 so its having problem.
    win xp sp2 means win xp service pack 2
    i think your probllem is solved thank you.
  • Zaid Anarwala
    Hi Jniffer,
    Please try to download dirext x 9 from the microsoft website, this feature helps to read the high level of graphics, please note your monitor could also be the trouble one, having said that try to set your monitor's resolution higher or check the games requirements for monitor resolution.
    If everything is done according to suggestions than i am afraid the HP 740 is faulty with the firmware issues.
SOURCE:
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
Have a HP DVD 840d burner, my pc only recognizes the cd rom not the dvd burner. any help to get this to recognize my dvd burner.
If you load a commercially-produced DVD disk into the drive, does it show in "My Computer" or do you get an "insert disk" message?
If it shows, right-mouse click on the icon, and choose "Explore".
Does it show files/folders, or is there an error-message?
Oct 11, 2010 | HP Computers & Internet
DVD drive doesn't recognize the disc
insert an unfolded paperclip or similar object into the little hole on the front of your cd rom drive to manually open it, insert a cleaning cd. if this doe snot rectify your problem check and original software disk (not a copy) and if its still not being recognised then replace the drive.
Jun 22, 2010 | HP m1170n PC Desktop
My HP DVD 740 won't recognize blank CDs
Sounds like the lens is dirty. Run a cd cleaner through the drive. That should take care of it.
Dec 15, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Dvd 740 media problem
jovanis114 --
If your drive was able to recognize a disk before, but now has stopped... POSSIBLE solution... (don't shoot the messenger on this one, lol!)
I'm sure you have tried, but have you cleaned your optics lately?
Using a Q-tip and a small amount of rubbing alcohol, and GENTLY rotate the swab across the lens, rotating it in the opposite direction you are wiping. This should "lift" any dust or grime from the lens. I would also clean the tray with a soft lint-free cloth (using an air-can just moves the dirt around, doesn't solve the problem)
Hope this helps!
-- RT
PS - Don't forget to vote!
Sep 09, 2009 | HP dvd740i DVD±RW Dual Layer Burner
I cannot get my DVD Rom drive to recognize any DVD
You need to install the DVD decoder that came with the drive such as PowerDVD or WinDVD. If you dont have the disks or setup files for those, you can download a free Windows DVD player program such as VLC Media Player that will work. http://www.videolan.org/vlc/
May 18, 2009 | HP Computers & Internet
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
When i try to burn on hp1040e dvd burner it wont recognize the dr
you may not install the proper drivers of your burner, install it again and use some other burner application like nero cd burner etc.
Feb 10, 2009 | HP DVD1040e DVD-RAM Burner
Cd/dvd rom
Have you tried unistalling the drive in device manager and rebooting, windows will automatically pick up the drive on restart and install the driver again for you.
Cheers
Jun 04, 2008 | Compaq Presario 700 470024-192 Notebook
HP dvd 740 doesn't recognize when blank discs are put in
Check IDE cable connection. You might need a new IDE cable. I had the same problem, until I did the aformentioned. Hope this helps.
Oct 06, 2007 | HP DVD 740VI 16X16 Dual Layer LightScribe...
HP DVD 740VI 16X16 Dual Layer LightScribe DVDRW Blk RTL (HPDVD704VI) Burner Logo
229 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
