Question about Masterbuilt 20070106 Electric Smoker
No smoke I have a Masterbuilt smoker and have made 600 lbs summer sausage, the element heats but I cannot get smoke
  • 7 Answers
Try this...
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Posted on Jul 03, 2010
Masterbuilt Smokehouse model 20070712 won't smoke wood chips at 225 degrees
I had this exact same problem with my Masterbuilt Smokehouse even when brand new. I notice there is some variability in the space between the top surface of the heating element and the bottom surface of the wood chip box. I measured about 1/4 inch between the two surfaces when the heating element was seated bottomed out and touching the wire grill below it. What I did to fix the problem was to gently (make sure everything is completely cold before doing this) lift up the end of the heating element farthest away from where it enters the enclosure just a little bit so that when you put the woodchip box in where it is supposed to go, the top surface of the heating element will now be in contact with the bottom surface of the woodchip box. This arrangement allows much greater heat to heat the wood chips during the part of the heating cycle when the heating element is on (naturally the heating element cycles on and off to regulate whatever temperature your are targeting for your food being cooked). Now, because of this contact, every time the heating element comes on, enough heat will enter the woodchip box to keep the chips ignited. My next step is I am going to put a small 1/4 inch thick piece of metal beneath the heating element and the rack that is under it to force the heating element to stay sitting 1/4 inch higher so that it is always in contact with the lower surface of the woodchip box. Making these improvements allowed me to continuously get smoke when the big smoke box was at 225 degrees F.
Without making this fix, the unit would stop producing smoke at 225. Hope this makes sense and helps you.
Aug 25, 2012 | Masterbuilt 20070106 Electric Smoker
My smoker does not smoke at 220 degrees it did fine in colder weather
Either the heating element or the controller on top of the smoker has failed. This is a chronic problem with Masterbuilt electric smokers. That's probably the reason it on has a 90 day warranty.
You can purchase the part(s) from Masterbuilt or from Factory Appliance Parts
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=491507&modelsID=135884&typeName=gas%20grill
Hope this helps you & thanks for choosing FixYa.
Sep 11, 2011 | Masterbuilt 20070106 Electric Smoker
What kind of charcol do we use for this item
Brandi, Electric Smokers do not use charcoal at all. Only wood chips. The electric heating element produces the heat. Smoking is a low temperature slow process. When mastered it can produce some fantastic food.
In case you have misplaced your Owner's Manual, I have included a link to it that you can download and print for future reference. In addition to the assembly instructions, it will walk you the process of curing the new smoker and how to smoke different foods.
http://www.masterbuilt.com/pdf/manuals/07092010%2020070910%20Manual.pdf
Hope this helped you. Enjoy your smoker!
Jul 08, 2011 | Masterbuilt 20070106 Electric Smoker
Smoker was working great. Went to smoke some ribs this morning and my controller won't go above 90. Help!
Your heating element is now probably inop. You'll have to go onto masterbuilt.com and order another element. Try this site:
http://www.masterbuilt.com/pm-smokers.html
Feb 26, 2011 | Masterbuilt 20070106 Electric Smoker
30" Masterbilt smoker won't get over 60 degrees. I
I am having the same problems with mine. I have rebuilt the connection, three times.
I am going to pull the element out and replace it with a single-burner heating element like the Proctor-Silex 34101. That will be plenty of heat for the smoking I do.
Jan 31, 2011 | Masterbuilt Electric 30inch Smokehouse ...
We have the masterbuilt 700 series digital smokehouse. The wood chips are no longer burning - we have no smoke. Is the repair easy and cheap?
You probably have a bad heating element, Turn the unit on then turn your digital heat to 275 and open door the heating element should become cherry red. If it doesn't then you have a bad heating element. If you do not get a digital readout then you probably have a bad digital control panel. Both of those parts can be replaced, however i do not know the price for either of those parts. If you have neither working then you may have a short or broken wire that is not making a full curcuit. Good Luck
Jul 28, 2010 | Masterbuilt ESQ30B Smoker
I purchased a masterbuilt smoker in Jan/2010 Model E 20070910. First time I used it had no problem with generating smoke but ever since I can not generate smoke I've tried pellets & even Hickory...
Try this...
Mike in Alaska
PSU313@yahoo.com
Jun 17, 2010 | Masterbuilt 20070106 Electric Smoker
My Masterbuilt electric smoker stopped heating will cooking
Mike in Alaska
PSU313@yahoo.com
Jan 24, 2010 | Masterbuilt 20070206 Smoker
Used the masterbuilt smoker only 5 times???
Mike in Alaska
PSU313@yahoo.com
Jun 20, 2009 | Masterbuilt 20070106 Electric Smoker
Masterbuilt 20070106 Electric Smoker Logo
407 people viewed this question
Top Masterbuilt Grilling Experts
Ted-L
Level 1 Expert
Paul Carew
Simon Flummox
Simon Flummox
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
